Hello from Noob
Old Dec 9, 2010 | 11:48 AM
omalley1537's Avatar
Default Hello from Noob
Hello everyone,
Just wanted to say hello, back in the GM fray after an ill-fated experiment with a Dodge Diesel (found out three things 1-I could have designed a better-built truck than dodge 2-Dodge warranty service suck worse than most 3-I can't afford to play in diesel land).
Picked up a CC/SB 07 Vmax 4x4 LTZ with about 40k on the odo. I absolutely love the truck and for my needs (very occasional light towing and DD) it fits much better than the 3500 Diesel Ram.
Besides saying hello, also wanted to ask a question. My truck reads about 30-ish on the oil pressure at idle when warm, 40-ish at cruise. The pressure comes right up when I accelerate, without any hesitation. Based on my searches this seems normal as it seems that the L76 doesn't have the oil pressure that I recall my 02 Sierra 5.3 having. My only concern is that when idling when warm, the gauge seems to "wander" somewhat between about 25-35. Seems rock-steady at cruise. Is this normal or is something bleeding down then pumping back up? Engine runs great, is quiet, and performs great. Is this something I should be watching or is it normal? I guess after a couple years of huge $$$ fixing the Ram repeatedly I'm a little gun-shy as well.
Old Dec 9, 2010 | 08:00 PM
07vmax1500's Avatar
my truck does the same.. holds 25-30 @ hot idle. mine has 61,570 on the clock, havent had any problems with mine.
Old Dec 9, 2010 | 09:37 PM
iamkeniff's Avatar
my 6.2 does that but at WOT it holds 65psi without a problem.
Old Dec 9, 2010 | 09:53 PM
double047's Avatar
14 Second Truck Club
My 5.3 has horrble oil pressure, always has...25 at idle and barely sees over 40ish ever, even at WOT...
Could just be the gauge, but the way I drive it I'm sure to find out...
Old Dec 10, 2010 | 09:55 AM
blackjack325's Avatar
Yea, Diesel world can get expensive, but oh so worth it!!!
Might slide into it in a couple of years. My 98 Yukon is still all I need for the ranch and to pull at this point. n my bros F250 handles the bigger stuff.
We need pics of your truck!!!
Old Dec 10, 2010 | 05:08 PM
fredkj3's Avatar
i put a manual guage on my last truck and the one on the dash was about 10 psi off.. so i wouldnt be too concerned with it..... I would watch it, if it continues to fall then i would be concerned
Old Dec 10, 2010 | 06:40 PM
lady3bglover's Avatar
I have a modded 5.3 and I'm 40 on the button @ 158k mi.
Mainesfinest
17
Apr 7, 2016 02:53 PM
MikeD.
Sep 18, 2015 09:55 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
MossyOakSilverado
Mar 25, 2009 09:51 PM
Thechevyman122
Nov 3, 2008 07:45 PM
