Has anyone installed
Old May 21, 2010 | 05:00 AM
Parke10's Avatar
Originally Posted by Three6GMC
just tap into the fuel pump trigger wire on the relay i did that before but on a older 2001 truck you gunna have to pull the fuse box off to do it but its really easy
idk if im just over cautious but i sure wouldn't wanna be taping anything fuel pump power related, that could put resistance in it or drop the voltage, that thing needs all the power it can get
Old May 21, 2010 | 06:44 AM
scooter k's Avatar
I wired mine to the instrument panel fuse block inside truck on driver's side left of steering column. There is some spare terminals available that have power with key on only but not with retained accessory power operating.
Just throw a inline fuse on power led.
Old May 21, 2010 | 11:00 AM
Tootall's Avatar
Originally Posted by 2007chevy5.3l
Theres power to it all the time. I have my radar detector plugged into it and its doesnt go off till i unplug it
Actually its a 12v outlet since the gmt900's dont have cigarette lighters/ashtrays
ahh ok, I have 2 and one is controlled with the ignition
Old May 21, 2010 | 04:22 PM
2007chevy5.3l's Avatar
Yeah ive heard about this location but I didnt know at what key position they get power. Im just glad ive got a few options at where to get power.
Old May 21, 2010 | 04:26 PM
Believe it or not but ive got 5 12v outlets. 2 under the AC controls on the dash, one in the center console, One on the back of the center console under the rear AC controls and one in the back by the rear hatch or lift gate, whatever you want to call it lol.
Old May 22, 2010 | 05:41 AM
schino's Avatar
it seems like this is very dependent on which truck it is.. now just realizing you have a tahoe. and also what options the truck has got. ive got a WT and there is def no switched 12v in the fuse panel in the truck. i even took the fuse box apart to see if i could solder some jumpers on the board to make an empty spot be used but there isnt even a place for the fuse to be able to connect inside. the circuit board that the fuses plug into seem to be made specific for certain options and not one general piece for all
Old May 25, 2010 | 11:24 PM
07LTrquick's Avatar
Ok So whatever you do and whoever said wire it to the pink or orange wire! That is ******* retarded.... Do your research guy! The newer trucks all have low volteage refference signals to the ignition lead that go to the computer. If you tap into this you will blow your ingnition out and need to get a new one once you figure out your truck wont start!! hahaahahaha Just an FYI for you. Let me know if you need a wirring diagram.... I used to build callway corvettes and am very familiar with the newer trucks!
Old May 25, 2010 | 11:41 PM
f4tal's Avatar
Originally Posted by f4tal
Hook it up to an ignition source an you should be good. I wanna say the orange or pink wire in the ignition harness under the steering column. Double check though, been a while since i worked on those Any accessory source will still turn it on when listening to the radio.
Hence the double check part...
why don't ya read in depth before ya start calling people effing retards.
anyways... there are plenty of wiring diagrams justin. the internet is your bestfriend in this case
Old May 26, 2010 | 01:26 AM
smokeshow's Avatar
Mod with training wheels
Not to thread jack, but on the flip side, what if you want something on when the key is turned to ACC? What fuse would you tap then? Like for instance, turning on amplifiers for a stereo.
Old May 26, 2010 | 10:59 AM
07LTrquick's Avatar
You would want to go to the fuse block under the dash. This has multiple 12v main powersource options. You could hook up there and it is pulled straight from the battery in this location.
As far as my comment earlier.... whoops.... my badd friend! But your right everyone here should be double checking there work at home. Grab yourself a multi meter and start pinning out your sources!
