Had a close call yesterday
Old Jan 14, 2013 | 02:24 PM
Gus 82's Avatar
Default Had a close call yesterday
So I got my gears in and about 500 miles on them. I decided to take it on the freeway yesterday and see what it has off the line now. Everything was going good since I the traction light kept flashing.... I get up to about 80 when I let out of it and start dropping back to cruising speed. I check my mirror and smoke starts pouring out from under truck like there is a leaf fire. I get the brakes hard and pull to the berm and hop out. Trans fluid is pouring out by the bell housing. At this point I am pretty concerned and called AAA to get the truck home. I get under the truck and started to look for a hole in the case even though I didnt hear any sounds when it happened. I found the Pressure line for the cooler came out from the transmission and was the source of the leak. Now I am going to convert everything over to -AN braided line and hoping since I was on decel and stopped within 20 seconds of seeing smoke I didn't wipe out 3-4... Truck has about 30k on it so I will use this time to pull the pan and change the fluid and filter.
Old Jan 14, 2013 | 02:44 PM
2000chevysilverado's Avatar
Factory warrenty still on it. Im geussing not though with mods in ur sig
Old Jan 14, 2013 | 03:09 PM
Gus 82's Avatar
Nope this one's on me....
Old Jan 14, 2013 | 03:21 PM
oakley6575's Avatar
I did all AN fittings on my rig and it is soo clean and easy. Any idea how much fluid it lost?
Old Jan 14, 2013 | 03:31 PM
Gus 82's Avatar
Quite a bit very fast but I am not sure on the amount. Im hoping that since I was slowing down so basically coasting when it started and then stopped asap I saved it.
Old Jan 14, 2013 | 04:32 PM
Z71crawford's Avatar
What size tires you running man? Just curious because I see you have level kit and 4.88s. Wondering if you squeezed 35s on a level kit or just went all out torque on 33s.
Old Jan 14, 2013 | 05:25 PM
Gus 82's Avatar
Factory tires are 32 but I think I'm gonna stick w 33. For the brief moment I was doing 70 it was like 2400 rpm
Gus 82's Avatar
Gear is what a 4.8 needs in a ext cab hands down
Old Jan 14, 2013 | 05:40 PM
Damn man I'd love to drive that, my 4.56 are getting installed now. Should've went 88s. How much MPG did up lose?
Old Jan 14, 2013 | 05:46 PM
Gus 82's Avatar
Since I have been in breakin so not really in it or freeway avg 17
