Front Pinion Bearing Gone AGAIN !!
Old Oct 21, 2015 | 08:09 PM
CDN SS's Avatar
Default Front Pinion Bearing Gone AGAIN !!
2010 1500 4wd with 80k ......... is this typical for these trucks ? truck not off roaded etc 33" tires 4.11 gears daily driver & towing original pinion went about 50k now its goin again rarely in 4wd although in winter I do leave in auto a lot
Old Oct 22, 2015 | 06:03 PM
No not normal something with the setup or bearing quality.
Old Oct 25, 2015 | 12:51 PM
CDN SS's Avatar
OK not typical Tks
Old Oct 26, 2015 | 02:13 PM
Probably not related but what weight and type of oil are you running in it. These trucks come with 80/90 dino oil in the front axle only. Theres a TSB for shift problems in really cold weather due to dino oil and you put 75/90 synthetic back in. Why they didn't put same oil front and rear from the factory is beyond me. No where in the TSB is bearing failure addressed but I did see you live where it's really cold so possibility out there if diff is full of molasses in cold weather.
Old Oct 26, 2015 | 06:05 PM
CDN SS's Avatar
Good to know Thanks
BLKSSLTT
Mar 20, 2016 03:39 AM
NateBower002
Oct 24, 2015 03:05 PM
alex1138biancale
Oct 21, 2015 07:41 PM
85SS/85GN
Oct 20, 2015 07:28 PM
