Front Diff Removal, 4x4 engagement issues
Old Jan 5, 2018 | 08:51 AM
Idryfly5's Avatar
Default Front Diff Removal, 4x4 engagement issues
Is this as simple as it looks? Unbolt the axle flanges, un hook electrical connections and vent tube, unbolt drive shaft, unbolt diff and lower?
Reason being, I must've muffed something up when installing the passenger side axle tube assembly when I changed the axle seal, so I'm just going to drop the entire assembly to make sure it is aligned when I re-install it. I get zero engagement when turning the ****. I can hear the actuator when it goes to engage, and the **** lights like it is engaged. No weird noises, just still 2wd.
Old Jan 5, 2018 | 09:10 AM
Atomic's Avatar
I have a gauge for that
Pretty much! You may need to turn the steering wheel left or right to clear the centerlink though.
Old Jan 5, 2018 | 12:41 PM
2002_Z28_Six_Speed's Avatar
I usually have to pop the steering link off to get the axle in and out. Only takes seconds with the right removal tool.
I also undo the top bolt on the diff and loosen the bottom but leave it in. Let the unit swing down closer to the floor. Then grab the diff and take out the bottom bolt. Works like a charm. Don't have to lift it as high.
Old Jan 5, 2018 | 05:19 PM
FFDP's Avatar
If the truck in his sig is the one he is working with he doesn't have much of an issue with steering links.
Just unbolt the power steering rack on the GMT-900's and lower it down so it can hang. Remove the cross beam frame support under the oil pan, it's just 4 bolts. Swing it towards the passenger side when you pull it out and it drops right down.
Old Jan 5, 2018 | 07:56 PM
Yep, no upper and lower housing bolts on GMT900s. Just the 4 outer tube bolts. I didn't even mess with my steering linkages, used a jack to help me wiggle and angle it out and in.
Old Jan 10, 2018 | 08:29 AM
Idryfly5's Avatar
Thanks for the info guys. Going to drop it tonight while the weather is somewhat decent and see whats going on. Hopefully something simple.
Old Jan 22, 2018 | 10:21 AM
Idryfly5's Avatar
So, if anyone is planning on doing this, I suggest dropping the front crossmember. Just 4 bolts/nuts and the diff comes out so easy. Also, if you have to change axle seals, drop the diff. It will save so much time and frustration being able to do it on a bench and not under the truck.
Old Jan 22, 2018 | 04:30 PM
swathdiver's Avatar
5 Year Member
So is it working now?
Old Jan 23, 2018 | 09:46 AM
Idryfly5's Avatar
Yep. When I pulled it apart, there was a washer that had fallen off of the shaft when I removed the axle tube. It was laying there staring at me when I opened it up.
Fellow294
Dec 26, 2009 11:24 PM
1slow01Z71
Jul 31, 2007 09:13 AM
Phantom
Feb 19, 2007 12:31 AM
