duals? or y pipe?
well i did my exhaust like 2 months ago i went with pacesetter long tube headers two 3 inch pipes(one from each header of course lol) into a magnaflow 2 in 2 out..well my question is whats better dual piping or just a y pipe?? do i loose any kind of throttle responce with duals
Thats way over kill, you need all the low end you can get and your losing alot with 3in true duals, even if your running one muffler. You should be running 2 1/4 piping (Dual ) if you wanna retain the majority of your low end, even then its not adviseable to do that on a bolt on truck.
Agreed completely. I'm sure the current setup flows great and you probably picked up power on the big end, but you're killing you low end torque. I was running 2.5" true duals on my 04 CC 5.3, full bolt-ons/cam/etc... and that was overkill. Best thing I ever did was to go back to a single 3".
When you go back to 3in y Pipe make sure you use one of the Flowmaster merge 2 to 1's, that will smooth the transition of the exhaust and kill some of the rasp. If you still don't like the sound put a bullet muffler about 1 foot after the merger and that should solve it compleletly. Good luck with whichever route you take.
TrickTurbo
Sep 23, 2015 08:41 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
