DoD and VVT deleted. Correct cam installed
Old May 5, 2013 | 08:53 PM
griff364's Avatar
Default DoD and VVT deleted. Correct cam installed
Got my AFM and VVT deleted. All in about a 24 hour period.
I also got the new cam that COMP sent me and installed it
Pictures are with and then without VVT
Here's how it sounds:
https://www.youtube.com/watch?v=RHOuagBa_NQ
Attached Thumbnails DoD and VVT deleted. Correct cam installed-0323031741.jpg   DoD and VVT deleted. Correct cam installed-0504031124.jpg
Old May 5, 2013 | 08:59 PM
Lowexpo's Avatar
What motor you have? Cam? More info.. Sounds great by the way
Old May 5, 2013 | 09:03 PM
griff364's Avatar
2011 GMC Sierra 5.3L
I went with a 222/224 .566/.568 lift and 112 lobe duration cam
I put 16 LS7 lifters in it, and swapped to a 3 bolt cam and also put on an LS2 timing chain dampener.
It desperately needs a tune. It still wants to stall every now and then when the rpms drop too fast.
Old May 5, 2013 | 09:13 PM
dick_landy's Avatar
Mine took just over 14 hours with a buddy. He's done a few before and I've had the front of the truck apart a few times so we were flyin good on it.
Old May 5, 2013 | 09:29 PM
Lowexpo's Avatar
Thanks man
Old May 5, 2013 | 09:34 PM
Nice lookin truck and sounds excellent. What is your current exhaust setup it sounds really nice.
Old May 5, 2013 | 09:38 PM
griff364's Avatar
That's good work. I only used my neighboor for help getting the AC compressor back on. For some reason, they didn't put a belt tensioner on my model. It makes it much harder getting in there with a pry bar to get the compressor mounted.
I put in about 16.5 hours of work.
Old May 5, 2013 | 09:40 PM
griff364's Avatar
I've got kooks LT headers going into a Y-pipe with high flow cats. 3" all the way back with a $25 dollar ebay muffler and then just a tip.
Thanks all for the compliments.
Old May 5, 2013 | 09:43 PM
griff364's Avatar
How did you make due with the oil pick-up tube bolt? My flange is welded all the way around so I couldn't dremil it to rotate the bolt hole to the outside.
I still didn't drop the oil pan, but I had to finagle it with a magnet while sitting up underneath the truck being eye level with the oil pump.
Old May 5, 2013 | 10:00 PM
dick_landy's Avatar
Kinda did the same as you but ended up dropping the pan. Newer trucks don't have the tensioner, I was going to grab one from a salvage yard but didn't feel like rolling in mud.
