DOD delete /cam nnbs 5.3
Old Nov 6, 2012 | 06:48 PM
97aztecgt's Avatar
Default DOD delete /cam nnbs 5.3
Hey everyone, from what I've read it seems you can't run a cam that has over .500 lift with the factory AFM/DOD? I'm really wanting to get a nice cam that will be nitrous friendly, but I don't want to deal with the bs of the DOD if it will rob me of potential power. I've read tons of threads of people that has started 'collecting' the DOD stuff for a nnbs 5.3, but has yet to do it. Anyone actually done this and wouldn't mind sharing their input on it? OR is there a cam out there that would still work with the DOD, but I could just disable the AFM?
Old Nov 6, 2012 | 07:28 PM
AUTOT3K's Avatar
Check out my "it's that time of the year" thread.
I just ordered my DoD delete list. About $400.
Old Nov 6, 2012 | 07:29 PM
AUTOT3K's Avatar
I'll copy and paste when I get on a computer later
Old Nov 6, 2012 | 08:24 PM
AUTOT3K's Avatar
SDAFMD53 is th part number
go to http://www.sdparts.com
and this is the list I ordered
DOD Delete Kit
Water Pump Gaskets X2 (kit only has 1...strngely)
GM LS Timing Cover Gasket
3 Bolt Sprocket
LS2 Dampener off your DOD list
LS Oil Pup Pickup O Ring
was $387 before shipping
i'm getting the rest of my cam stuff from texas speed
Old Nov 7, 2012 | 05:12 AM
97aztecgt's Avatar
Do you need to replace the headgaskets as noted in the sticky, "DOD parts list?"
Old Nov 7, 2012 | 06:17 AM
LGSONE's Avatar
Yes, you will need to replace the head gaskets. After all if it coming that far apart you might as well. I opted for the LS9 gaskets for when the boost project comes along. My truck is an '08 so I went ahead and replace several other sensors (hard to get to ones) and several other gaskets, front of motor, valve cover, intake, exhaust. If your on a budget I was told "some" could be reused but I'm going to turbo my truck so I wanted as much as possible ready for that. Better safe than sorry, and piece of mind things are right. HTH
LGSONE
Old Nov 7, 2012 | 08:21 AM
97aztecgt's Avatar
I'm just not sure I want to tear into the motor like that, yet. Is there a cam that can work with the DOD?
Old Nov 7, 2012 | 09:42 AM
Robert91RS's Avatar
Not thats worth your time and money IMO.
If you cam it the warranty is toast anyways, so you might as well remove the weak pieces while you're inside.
Old Nov 7, 2012 | 10:24 AM
97aztecgt's Avatar
Sigh... I guess I'll start collecting parts for it. Are the heads that on the truck now a decent head to get a P&P job done on them?
Old Nov 7, 2012 | 10:41 AM
AUTOT3K's Avatar
Which ones do you have? 799 or 243 are definitely good!
