Did I make an oops? Pacesetter ORY /w a 6sp?
Old 12-22-2012, 11:51 AM
AUTOT3K's Avatar
or would these work better?
there's two different styles, so I'm not sure
Old 12-22-2012, 05:07 PM
iamkeniff's Avatar
V Band Clamps
V Band Exhaust Clamp
Old 12-22-2012, 09:10 PM
AUTOT3K's Avatar
Originally Posted by iamkeniff
So which one do you suggest? Or will both work well?
Old 12-22-2012, 09:17 PM
AUTOT3K's Avatar
nevermind, I checked the links on my computer and could read it better.
so do I need 2 in total? and just weld the y-pipe connections together once i've got it together? or do every joint and order 5 v bands all together??
Old 12-22-2012, 11:11 PM
iamkeniff's Avatar
2 for header to y pipe and 1 more if you want to fab up the peice that goes under the trans to remove just that section if you drop the trans
Old 12-23-2012, 07:03 AM
rijrunr's Avatar
I used the stainless band clamps from summit and they work great. Had one that leaked slightly after about three months, but one of the bolts just loosened a couple turns.
Old 12-23-2012, 08:56 AM
AUTOT3K's Avatar
That's a good idea.
I ordered the ceramic coated ones. Am I safe to mig weld those? Just grind the surface I'm welding and use my normal heat settings for exhaust pipes? Or should I decrease the temp a bit?
Old 12-23-2012, 07:48 PM
iamkeniff's Avatar
Mig is fine, an normal exhaust setting is fine. Weld the outside and inside then take a flapper wheel and smooth the inside welds
Old 12-23-2012, 08:02 PM
AUTOT3K's Avatar
ok sounds good, I do happen to be pretty good at welding /w my previous mini builds, got real good with a mig by the end of a full shaved dime haha
i'm gonna order those tonight so that they can get shipped tomorrow and i'll see them around the same time as my headers
Old 12-23-2012, 08:23 PM
AUTOT3K's Avatar
ouch, $100 for 3 v bands 3 clamps plus shipping!
Quick Reply: Did I make an oops? Pacesetter ORY /w a 6sp?
