Did I make an oops? Pacesetter ORY /w a 6sp?
I've been waiting on my cam and LT order to arrive and I was doing a search looking to find what band clamps everyone is using on theirs and I came across a thread where someone mentioned it didnt fit his 6sp so hes selling it.
did I not do my research properly and order something that wont work? I ordered the Pacesetter Coated LT's /w 3" ORY if i'm good to go, what are the band clamps everyone used? and I need 3 of them? thanks |
Should be fine man my buddy has a 6 speed with the same set up as you.
Originally Posted by Z71crawford
(Post 5041943)
I will update after install |
Wait is your truck 4wd? Because if so the pacesetter y pipe won't work. I have these headers on my truck right now for the break in process and I had to get a custom y bent at the exhaust shop because of the driveshaft coming from the t case to the front dif. If yours is 2wd then you shouldn't have any problems. Check out stainless works there a site supporter and make great product they can get you some nice clamps.
Originally Posted by Three6GMC
(Post 5041995)
I'll check out stainless works and see what they have for clamps! |
Dont use band clamps....they wont last.
Do a ball and flange setup, vbands, or 3 bolt flanges with a copper gasket |
Originally Posted by iamkeniff
(Post 5042039)
(Post 5042039)
(Post 5042039)
(Post 5042098)
Agreed the clamps tht come with it suck!! Only lasted about 2 months b4 it started to leak.
