Did I make an oops? Pacesetter ORY /w a 6sp?
Old Dec 22, 2012 | 11:51 AM
AUTOT3K's Avatar
or would these work better?
there's two different styles, so I'm not sure
Old Dec 22, 2012 | 05:07 PM
iamkeniff's Avatar
V Band Clamps
V Band Exhaust Clamp
Old Dec 22, 2012 | 09:10 PM
AUTOT3K's Avatar
Originally Posted by iamkeniff
So which one do you suggest? Or will both work well?
Old Dec 22, 2012 | 09:17 PM
AUTOT3K's Avatar
nevermind, I checked the links on my computer and could read it better.
so do I need 2 in total? and just weld the y-pipe connections together once i've got it together? or do every joint and order 5 v bands all together??
Old Dec 22, 2012 | 11:11 PM
iamkeniff's Avatar
2 for header to y pipe and 1 more if you want to fab up the peice that goes under the trans to remove just that section if you drop the trans
Old Dec 23, 2012 | 07:03 AM
rijrunr's Avatar
I used the stainless band clamps from summit and they work great. Had one that leaked slightly after about three months, but one of the bolts just loosened a couple turns.
Old Dec 23, 2012 | 08:56 AM
AUTOT3K's Avatar
That's a good idea.
I ordered the ceramic coated ones. Am I safe to mig weld those? Just grind the surface I'm welding and use my normal heat settings for exhaust pipes? Or should I decrease the temp a bit?
Old Dec 23, 2012 | 07:48 PM
iamkeniff's Avatar
Mig is fine, an normal exhaust setting is fine. Weld the outside and inside then take a flapper wheel and smooth the inside welds
Old Dec 23, 2012 | 08:02 PM
AUTOT3K's Avatar
ok sounds good, I do happen to be pretty good at welding /w my previous mini builds, got real good with a mig by the end of a full shaved dime haha
i'm gonna order those tonight so that they can get shipped tomorrow and i'll see them around the same time as my headers
Old Dec 23, 2012 | 08:23 PM
AUTOT3K's Avatar
ouch, $100 for 3 v bands 3 clamps plus shipping!
