Dead in the water!!!!!
Old Feb 26, 2013 | 08:17 PM
I got a ben franklin on fuel pump taking a dump on it. The 069E is simply the fpcm module sending a code to the pcm to command a check engine light. Fuel rail pressure sensor perf code 191 usually sets when the pressure drops as the pump is failing.
Scan the FPCM and see what codes it has set internally.
Old Feb 26, 2013 | 08:22 PM
Onetogofast's Avatar
My buddies 09 Denali was idleing at like 2K and had lean codes and was acting very stupid, dirty MAF
Old Feb 27, 2013 | 11:35 AM
silver-mod-o's Avatar
Hunt&Fisherator
I havent been able to really dig too deep with work eating up so much time but I did put a guage on the rail and as soon as the key is turned over it'll make about 20psi and fall off to nothing. It was enough to crank the truck but now it wont even do that. I did get it home on a trailer last night. I'm taking a half day off Friday to get this thing fixed since I'll be out of town for a week as of Sunday evening.
Old Mar 2, 2013 | 07:11 AM
Hunt&Fisherator
Dropped a pump in it last night and cleared the codes. Cycled the key and she fired right up. No problems. I didn't go road test it since I had several adult beverages but it idled fine for about 20min and didn't stall in gear or brake stalling it so I'd say we're fixed!
Old Mar 2, 2013 | 07:20 AM
mdwatts11's Avatar
Nice to know. Did you just put in an oem pump?
Old Mar 2, 2013 | 07:29 AM
Hunt&Fisherator
I put in a Delphi replacement, but next to the OEM pump that came out it was identical. Pump and all the connections looked exactly the same. Only difference was the indexing tab on the top of the pump was in the wrong place. I trimmed into fit in the original slot and put the lock ring on. No biggie. Took about an hour and a half and about 10 10oz Millers
Old Mar 2, 2013 | 06:13 PM
Delphi is the OE supplier for GM fuel pumps.
Old Mar 3, 2013 | 07:18 AM
Hunt&Fisherator
Probably why the pump and electronics looked identical
Old Mar 17, 2013 | 10:53 PM
Glad to hear its fixed
kainzien
Nov 10, 2023 11:37 AM
turbo6c3
Oct 5, 2015 06:11 PM
5speedsilverado
Sep 25, 2015 06:50 PM
jfuegner
Sep 22, 2015 12:30 PM
