View Poll Results: Dyno vs Data Log
Dyno Tune
60.00%
Data Log
40.00%
Voters: 25. You may not vote on this poll
Considering Dyno Tune
hey guys
I've been doing some searching on google, read some Camaro forum stuff, F150 forum stuff also some jdm stuff just to see and even in our own backyard this question was never actually answered. lots of "you should do" or "it should do this"
I am considering getting a dyno tune, I have the black bear auto cal and it was great however after my recent mods (listed in sig) he's been having a hard time nailing it down, I get idle surges or cruise control run on effect at low speeds, hesitations between shifts; he's got it pretty close but I just feel like I could get "more" out of the truck
I was originally looking around locally just to get a dyno pull but then I came across this place and I've heard the name lots and the guy is quite known for his great tunes, the dyno price is fair and so is the tuning price, I briefly emailed him and he says quote "I can gurantee better results" he also offers free updates and what not.
so is it worth it? do dyno tunes give better tuning and power then the auto cal?
here's that shop Wester's Garage
thanks!
thanks!
PLUS they actually take their harder to tune ones down to Westers!
Tilley isn't to far away, from me at least and then I can stop by Brooks wrecking yard to see what I can find in regards to a HD hood
if I do end up going that route I mean
dyno tune is for WOT performance. if you're happy with that part of the tune, and unhappy with the drivability you need to focus on actually cruising the truck around town to nail the issues.
has anyone else had that issue?
I know Justin is probly getting annoyed with it cause the emails went from "give this tune a try" to "here" and it seems to be one or the other, he gets the surge fixed but then the run on is worse...gets the run on fix then the surge is worse
edit to add
its not a mechanical issue cause it doesnt do it on a cold start driving and its intermittent on hot driving; just when it does do it its annoying
so thats why i thought maybe in person on the dyno would give better results
are you 1000% sure there are no vacuum leaks? which throttle body are you using? (cable/electronic?)
my last setup had to have the throttle cracker table completely removed to cure the idle hangs and surges. i dont think it's normal but it was what the engine wanted.
I'm using the factory TB, which is 87mm I believe? and its electric.
