Catch Can Install
Old Mar 27, 2011 | 11:05 PM
SilverDog's Avatar
I'm actually using the same catch can. Construction isn't bad, but like noted above the internal design needs improvements. I put an extension on the inlet side, with some mesh material to collect oil.
Old Mar 28, 2011 | 05:31 AM
skipperdaddy's Avatar
i shouldve tried that one! LOL!
Old Mar 31, 2011 | 09:38 AM
What is the purpose of the catch can for our trucks? The only vehicles I ever see running them are old school SBCs with wild cams and they are for catching coolant not oil.
Old Mar 31, 2011 | 09:46 AM
iamkeniff's Avatar
the catch can is to catch oil being forced into the intake
Old Mar 31, 2011 | 10:56 PM
fredkj3's Avatar
its purpose is to catch oil from the oil/vapor mist that is coming from the pcv system and being fed back to the intake ....
the oil tends to fall in the intake and gunk up... so if you catch the oil then it should help your intake from gunking up..
they are really needed on forced induction applications
Old Apr 1, 2011 | 01:54 PM
Thanks for the info, I will look at getting one installed ASAP before I get too many miles on the truck.
Old Apr 2, 2011 | 06:45 PM
Iraq Sucks's Avatar
Would this help with the oil smell coming into the cab from the vents for motors with breathers?
Old Apr 3, 2011 | 12:57 AM
double047's Avatar
14 Second Truck Club
Nice install.
Old Apr 3, 2011 | 04:24 PM
Karpo's Avatar
So after 1 week, I took the catch can apart... there was alittle oil and carbon build up inside, however there was also oil residue in the line going to the intake as well. I added some tubing inside on both the supply line (almost down to the bottom of the can) and return line (about half the length of the can) similar to Silver Dog's picture above. I then put some crankcase filter material in both so not only will it be filtered coming in, but also going back out to the intake. This is not a permanent solution by any means because the filter material will have to be changed, so I will have to take it back apart to change the filters. I am more interested in seeing how much oil is in the can next weekend and if the intake line is finally dry! I'll keep ya'll posted...
Old May 27, 2013 | 04:41 PM
Hubie151's Avatar
Registered User
Default hose
what size of hose did you use? the kit i ordered came with a small section of clear braded line. Also, inside the can, there isnt enough room on the fitting coming in to add some hose to get to the bottom of the can.
ferrellrooster
Mar 6, 2025 03:22 PM
Silveradorst07
Dec 31, 2015 12:04 AM
DrX
Aug 11, 2015 07:25 AM
TX Tahoe Z71
Aug 7, 2015 03:58 AM
