Cargo Light?
Old 01-13-2013, 05:05 PM
KC_kid's Avatar
Originally Posted by 0235SS93
I just wired in a seperate switch. Mounted it in my overhead console.
Got power and ground from the console harness and tapped the feed wire into the existing cargo light wire. There was a how-to floating around.
I also did this except it's on lower dash panel, down kinda by my left knee and I got power from... well not sure right now but it was already fused. I feel it's way more convenient this way, especially while driving at night and checking on load (you can't see out the back window when dark and dome lights on). The way GM did it is pointless, I don't care what excuse you give. The switch I used has a red light on it when it's on, so I don't forget it. And it's not on RAP power so I can use it anytime even with no key or accessories on.
Old 01-13-2013, 05:28 PM
KC_kid's Avatar
Cargo light wire is white with black stripe in the pink plug pin 2 on BCM.
Old 01-13-2013, 06:22 PM
JCunningham's Avatar
just stating thats why they did it. Checking your cargo going down the road is a good reason to have a separate switch.
Old 01-14-2013, 03:55 AM
97aztecgt's Avatar
Originally Posted by Fiveminutes
does anybody's cargo light NOT come on when opening the doors.
i think mine did at one point but now they dont.
caused by LED interior lights maybe?
Mine do not come on when the doors are open.. Damn.
Old 01-14-2013, 08:33 AM
KC_kid's Avatar
There is a dome override button to toggle that function off/on, you might want to check that switch.
Old 01-14-2013, 12:14 PM
NKPPhil's Avatar
Dome Lamp Override - The dome lamp override button is located next to the exterior lamps control.
(Dome Off): Press the button in and the dome lamps remain off when a door is opened. Press the button again to return it to the extended position so that the dome lamps come on when a door is opened.
RustyD
05-23-2016 07:04 PM
dantheman1540
02-24-2016 09:56 PM
carid
10-28-2015 08:24 AM
carid
10-01-2015 09:22 AM
Lthompson
09-21-2015 07:06 PM
Quick Reply: Cargo Light?
