Cannot get truck to move
Old Jul 23, 2012 | 05:21 PM
1Slow4eight's Avatar
formerly TheRawdoh1 (2013-08-16)
Default Cannot get truck to move
Just finished putting a Yank 3600 in the truck ..we dropped it and put it.on reverse and truck doesn't move. Poured total of 4quarts of transmission fluid ..have the rear in the air. We put.it.in.REVERSE NEUTRAL AND DRIVE and the wheels spin forward . Any one knows why truck does not move? THANKS.!
Old Jul 23, 2012 | 05:33 PM
BlackGMC's Avatar
Resident Retard
Did you give it some throttle? Also is the fluid full?
Old Jul 23, 2012 | 05:46 PM
Friends are saying the converter should click twice when we first put it into the transmission ..we are going to release the converter from.the three bolts and try to spin it till we hear it click
Old Jul 23, 2012 | 05:50 PM
BlackGMC's Avatar
Resident Retard
I think it is supposed to click 3 times. Hopefully you did not break the Pump
Old Jul 23, 2012 | 05:54 PM
Which pump? What are the symptoms of breaking the pump?
Old Jul 23, 2012 | 05:57 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The symptoms youre describing is a broken pump. You didnt seat the converter all the way and cracked teh pump when you bolted the trans to the motor.
Old Jul 23, 2012 | 06:04 PM
Would the pump be leaking? There's no leaks at all
Old Jul 23, 2012 | 07:02 PM
1slow01Z71's Avatar
No, it wont drip fluid.
Old Jul 23, 2012 | 07:13 PM
SLOXCAB's Avatar
If Alan helped you then your fucked lol
Old Jul 23, 2012 | 07:52 PM
GMCtrk's Avatar
You need to measure the distance from the converter bolt hubs to the face of the bellhousing. The number of "clicks" isn't reliable with an aftermarket converter imo.
