Can you put a 6L80 in a RCSB?
Old Jan 8, 2010 | 04:55 PM
FrankyRST's Avatar
So......does anyone know what else I would need? The truck is mostly complete except for the engine and seats and the crashed rear so I can pretty much get watever I would need.
So if anyone knows what I would need to get off of the truck let me know because I plan on going to go see it again later on.
Old Jan 10, 2010 | 10:53 PM
norris_83's Avatar
speartech.com
Old Jan 10, 2010 | 11:02 PM
RibeiroBJJ's Avatar
Praise The Lowered
Originally Posted by norris_83
speartech.com
The owner has done it to a rclb
Old Jan 12, 2010 | 12:32 PM
Wonderer876's Avatar
Computer reflash from the dealer to get the 6l80e programming is alll i was told besides the mechanical parts. Same as putting a 4l80e in a NNBS
Old Jan 12, 2010 | 01:30 PM
pewterliftedz's Avatar
i would think u would need the driveshafts right?
Old Jan 12, 2010 | 05:23 PM
Bo185's Avatar
Get the harness off the truck as you'll need it to run the wires to the 6l80. The TCM is internal to the 6l80 as well, so that's good. You'll need the column shifter stalk as well as it has the TUTD selectors. Might need the cluster as well.
Get hte rear cross member and drive shaft if it was 2wd.
Old May 19, 2010 | 05:56 PM
FrankyRST's Avatar
So I have a 2WD 6L80 (w/ converter), tranny crossmember, and TUTD shifter. I would need a PRNDM cluster so that it would look stockish, and I would need a custom driveshaft.
I'm also gonna need to take it to the dealer to get it reflashed for the 6L80.
what else do I need? anyone done the swap that could provide some info?
Old May 20, 2010 | 10:43 PM
Mang213's Avatar
Ive got the same goals as you. I already have the 6L80, but need all the other hardware necessary to get it up and running. Im definitely interested in seeing what others have to say about this
Old May 23, 2010 | 01:57 PM
FrankyRST's Avatar
I want to do it too but I just dont know if I have everything or have all the steps down to do the swap.
Bumpers
Aug 4, 2024 09:44 PM
OHsixLS3
Dec 27, 2016 09:30 AM
AHelm3
Apr 8, 2016 07:51 AM
thunder550
Oct 8, 2015 04:53 PM
