Cam for a 5.3 too much or good for DD?
Old Nov 10, 2014 | 12:18 PM
1CL3ANSUP3RSPORT's Avatar
Default Cam for a 5.3 too much or good for DD?
Is this too much for stock 5.3, or would this work great with heads Fast LSXRT intake?
Lift is 0.590 224/232 115 LSA
Old Nov 10, 2014 | 01:33 PM
Guessing you read this article:
4.8L VS 5.3L Engine - Tech - Little LS Slugfest - Super Chevy Magazine
It mentions that cam specifically and talks about the gains to be had on the 4.8 and 5.3 with heads and an intake.
Personally, I think it may be a bit big for a 5.3L, but a good tune goes a long way on what is considered good drivability and "too much" is largely personal preference.
If you don't mind a little shudder at lower RPMs, it would probably work just fine. But I would consider getting it with a few degrees of advance ground it to increase cylinder pressure and keep the low end up. Like 115+3
I think that cam probably still has a couple of degrees of negative overlap which should keep it relatively tame.
Old Nov 10, 2014 | 01:50 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
I also feel like that is too much for a 5.3, especially a daily driver. Realistically, you would want about a 3500 stall behind that cam to overcome the dead spot down low. I would suggest our 220R on a 1112 LSA.
It's on sale, too!
Texas Speed Camshaft Package w/ Single Beehive Valve Spring
Old Nov 10, 2014 | 02:24 PM
Yeah I read that article yesterday , most cams I see people use for the 5.3 are not a crazy for a stock truck. Just curious about that cam, my bro keeps telling me to have isky spec a cam out for me... I was considering the EPS truck torque cam 1
Intake Duration: 214 Degrees at .050" Tappet Lift.
Intake Lift: .600" with 1.7 rockers.
Exhaust Duration 220 Degrees at .050" Tappet Lift
Exhaust Lift .564" with 1.7 rockers.
115 Degree LSA
Old Nov 10, 2014 | 04:30 PM
ltr450ryder's Avatar
Ht1 cam would be a good choice too
Old Nov 10, 2014 | 05:08 PM
Vortec350ss's Avatar
It's more cam than I would DD a 5.3 with.
steves86ta
Jul 28, 2015 10:21 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
06 4.8
Jul 15, 2015 07:17 PM
chevy1224
Jul 13, 2015 07:50 AM
07NBSChevy
20
Jul 8, 2015 07:27 PM
