Need some help asap.
Old Nov 10, 2014 | 08:18 PM
fctry286's Avatar
Default Need some help asap.
I took my throttle body off to clean and paint. Well I removed the black cover to the the tps. And put everything back together and have tons of codes for tps. I dont think I installed the gear or cover or something right. Any one know how to set the tps?
Old Nov 10, 2014 | 09:28 PM
FFDP's Avatar
A scan tool that can command a idle relearn might be able too, thats only if something didnt get put back together wrong.
Old Nov 10, 2014 | 09:32 PM
TXsilverado's Avatar
i agree. log your TPS voltage at zero throttle and report back.
Old Nov 10, 2014 | 10:20 PM
fctry286's Avatar
ok, i will check that
Old Nov 10, 2014 | 10:26 PM
fctry286's Avatar
ok my commanded is at 100% when wot, but absolute is only 83.9 is that normal?
Old Nov 11, 2014 | 10:58 PM
FFDP's Avatar
Yes.
In a program like HP Tuners, the max TPS you will see is 84%.
Old Nov 12, 2014 | 02:31 AM
fctry286's Avatar
Ah ok, well that makes sense. so i guess all is good. I did an idle re learn and it has been running ok. thank you.
GM1697
Sep 28, 2015 08:28 PM
custm2500
Aug 22, 2015 11:46 PM
TN_TRITON
Mar 15, 2007 08:27 AM
Kingpimp
Mar 6, 2007 06:35 PM
