best CAI for a 08 denali ?
Old Sep 10, 2011 | 10:39 PM
rice eater 03's Avatar
Originally Posted by pl4yboy
It's under the hood. Do you drive around with the hood up? No one sees under there except for you. Build for function.
if function was all i cared about...why the hell would i have bought a denali?
this is under the hood of my silverado ss..so its kinda hard to pop the hood on that..and then pop the hood on the denali and not care lol but i get what your saying ..i guess its just havin a new toy and im lookin for some fun projects for it Name:  0827081647b.jpg
Old Sep 10, 2011 | 10:50 PM
ak2007r6's Avatar
Would you please post some pictures of how you did yours? I plan on keeping the stock airbox and it has a drop in K&N right now. I've just been looking for a good intermediate tube. The new MAF setup is hard to work around. If you've found a way around it, I'd love to see it.
Originally Posted by 8UALIVE
^^^^ x2
It's nothing special looking but it's air tight and was a noticeable difference. I am going to be ordering some parts from Intercooler Pipe Fabrication - Silicone Intake Systems Auto Parts today or tomorrow and redo it so it looks just a little better and I think I can get a better fit. The tube coming off the air box is at an angle and it's tough to get it to all line up how I wanted it to.
The pics below is from when i was fitting it up and checking the connections so not all the bands are on and the breather hose is not drilled and hooked up to the tube.
I will take lots more pics and do a small write up when I get my new parts and get it all cleaned up
Old Sep 10, 2011 | 11:02 PM
pl4yboy's Avatar
Banned
What did you do for the PCV?
Old Sep 10, 2011 | 11:04 PM
pl4yboy's Avatar
Banned
Most likely for comfort, which is another function. There is hardly a noticeable difference in outside appearance. Another thing... the only thing you ever need to show anyone is your tail lights. Popping hoods is for ricers and Lightnings that need to cool down.
Old Sep 10, 2011 | 11:12 PM
ak2007r6's Avatar
Bought a 2' section of 4" and a 4" street elbow from Lowes. The rubber connectors are a 4" to 3.5" reducers.
Old Sep 11, 2011 | 12:21 AM
pl4yboy's Avatar
Banned
PCV = Pressurize Crank Ventilation.
In the stock intake tube there is a small hose that is plugged into it from the intake. If it is not plugged in, there is a chance that that it will throw lean codes. My 08 didn't throw them, but my 2010 did. The new tube needs to be tapped for that hose somehow.
Old Sep 11, 2011 | 07:56 AM
ak2007r6's Avatar
PCV = Pressurize Crack Ventilation.
See above. The hose is hooked up just didn't post with it hooked up. The two pics above are from when I was test fitting it and seeing if I had to trim anything.
Old Sep 11, 2011 | 08:00 AM
ak2007r6's Avatar
Never mind I did have a pic. I had some clear vinyl tubing from another project already that was the right diameter so I just used that and a Hose Barb A-201B (5/16" Barb, 1/4" MIP) and a couple small hose clamps.
Old Sep 11, 2011 | 08:11 AM
rjwz28's Avatar
Man Motor club
I did an Airaid M.I.T. and an Airaid Synthamax dry drop-in. About $150 if you get both together as an Airaid Jr kit, looks clean, installs easily, and flows more air than stock.
Old Sep 12, 2011 | 09:44 PM
raptor700rnut's Avatar
I'm new on this site but have been checking it out for a while. I have a S&B intake on my 08 SD. I do a lot of diesel performance in my shop and have had good luck with S&B's. I decided to try one out. Fitment was very good and overall looks are good as well. S&B uses 8 layers of cotton on their filters while K&N's use 4-6 depending on application. I haven't seen anybody on here with this setup so I thought I would throw it out there. They retail for $270.
