Belltech Lowering Struts
Old Mar 14, 2011 | 12:56 AM
VMax626's Avatar
Default Belltech Lowering Struts
How much should it be to have Belltech Lowering Struts installed at a shop?
Old Mar 14, 2011 | 01:01 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
2-2.5 hours at your local lobor rate, plus wheel alignment.
Old Mar 14, 2011 | 05:48 AM
iamkeniff's Avatar
75-80 an hr and 75 for the alignment (thats the rate here anyways)
do you have a air compressor and your basic tools? jack and jack stands? some extra time to work for a couple hours? how about time to run to the parts store and borrow a spring compressor? if you can answer yes to those, hell do it yourself and save the 150-250 they are going to charge you imo
Old Mar 14, 2011 | 12:14 PM
javzh's Avatar
it's pretty simple to do. I borrowed the spring compressor from autozone. Like iamkeniff said Jack, jack stands, basic tools, spring compressor, and some time, and it's free.
Old Mar 14, 2011 | 12:32 PM
Three6GMC's Avatar
^^^^ yeah man very easy to do, most auto parts stores will even loan you the spring compressor tool.
Old Mar 14, 2011 | 03:23 PM
Beyond Static's Avatar
Very easy to install as the others have said. I've removed mine 3 or 4 times without even having to take the wheels off
Old Mar 15, 2011 | 02:39 AM
VMax626's Avatar
With the belltech strut set up like this it should lower the truck two inches?
Old Mar 15, 2011 | 03:14 AM
silverado1ss89's Avatar
I think ima buy the same struts.. I just wanna go 1 inch lower i'n the truck
Old Mar 15, 2011 | 06:41 AM
javzh's Avatar
Yes, iirc I use just one 10mm ring an just switch over the oem spring perch and boot.
Old Mar 16, 2011 | 08:25 PM
You'll probably want to cut the bumpstop down some. IIRC when mine was set at 2" the bumpstop was smooshed in there
