Battery relocation jump start?
Old May 8, 2018 | 09:26 AM
crashmymax's Avatar
Default Battery relocation jump start?
I have my battery mounted in the spare tire location and assumed I would be able to charge or jump start the truck by connecting the + to the distribution block under the hood and the - grounded to a ground. I hooked up a trickle charger like this and it would not work. Will this not work for some reason?
Old May 8, 2018 | 09:43 AM
JeffT's Avatar
Stupid question maybe, but are you sure you have the + distribution block connected to the battery now that it's in the back?
Also, you said trickle charger so I'm thinking Battery Tender or CTEK, sometimes those take a while to charge. Did you try putting a DMM on the bat to verify that it was/wasn't charging while hooked up?
Old May 8, 2018 | 10:10 AM
crashmymax's Avatar
Yes its connected correctly I'm currently driving the truck. When I connected the charger it goes to fault and wont charge. The charger is working correctly as I charge batteries with it all the time. The fact that it goes to fault makes me wonder if that is not a safe way to charge or jump.
Superado
33
Aug 27, 2012 02:51 PM
jakebdb56
Sep 1, 2008 02:53 PM
DamnYankee
May 28, 2008 06:35 PM
04Denali
Aug 2, 2007 07:54 AM
Flyer
13
May 28, 2004 08:04 PM
