Asp pully install help!
Old Feb 24, 2010 | 04:09 PM
SnakeOiler's Avatar
Originally Posted by dlt76028
... Your stock bolt won't start threading to pull the pulley back on, ...
That is NOT the way to install it.
Old Feb 24, 2010 | 05:03 PM
Preston129's Avatar
Originally Posted by Tootall
That's how I used to do it on cam swaps until I got the crank install tool.
Which tool if you don't mind me asking?
Old Feb 24, 2010 | 05:57 PM
dlt76028's Avatar
What exactly is wrong with it? I know a TON of people that do it with no problems.
Old Feb 27, 2010 | 07:42 PM
Mrgoodwrench3's Avatar
The special tool threads into the crank. There is a large nut that then turns on the tool and pushes the pulley onto the crank. This way the threads in the crank are not used to pull it on. All the stress is on the tool.
Old Feb 27, 2010 | 11:08 PM
Red Heartbeat's Avatar
buy a piece of all thread the size of bolt, a couple large washers and nut the size of the all thread and use that to pull the pulley onto the crank. Heat is a bad thing. Hammers are a no-no on a crankshaft. Longer bolts sometimes bottom out before the pulley is all the way on. There's a reason GM puts a specific length bolt in the engine. The ARP bolt sounds intriguing though $4 for a stock bolt isn't bad at all and the balancer is installed per GM specs. After seeing a few balancers come loose and fall off the crank I fear doing anything other than the stock bolt. How tight are you supposed to tighten the ARP bolt?
Old Feb 28, 2010 | 10:42 PM
Atomic's Avatar
I have a gauge for that
ARP bolt is suppose to be 250ft/lbs.
Stock bolt is 37ft/lbs and then an additional 140 degrees of rotation.
Old Apr 11, 2010 | 12:14 AM
007gmc's Avatar
My dad bought the gm shop manuals for his 2003 Corvette and it called for 240 ft/lbs on the stock bolt when we did his cam
Old Apr 11, 2010 | 12:24 AM
iamkeniff's Avatar
i heard 190ft lbs on the ARP
i put a 1/2" wide flat head in the flywheel bottomed it out on the motor. i put my 250ft lbs tq wrench on it an tightened as tight as i could pull it by myself i didnt get 250ft lbs out of it lol
i used liquid wrench on the threads an a lil on the surface of the bolt an pulled it on as tight as possible
LCHEE
Oct 24, 2020 04:10 PM
echoman
Aug 22, 2015 01:53 PM
zblee
Aug 3, 2015 03:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
