Alignment issues
Old Jun 21, 2016 | 11:56 PM
fillpot's Avatar
Default Alignment issues
Guy's have a 2013 GMC 6.2, ext cab, lowered 4 and 7, and I cant keep it aligned, especially on passenger side, it has belltech off set bushings and keys with there adjustable struts which I'm beginning to not like as much as I thought, also the kit is a mcgaugheys, (spelled that wrong), anyone ran into something along these lines. THANKS!
Old Jun 22, 2016 | 08:11 PM
iamkeniff's Avatar
What does the front consist of?
I run oem struts, oem control arms, belltech 2* upper bushings, mcg spindles and mcg coil relocators. I've had 0 issues with getting it aligned well over 50k now
Old Jun 22, 2016 | 09:54 PM
fillpot's Avatar
It's just the mcg spindles belltech adjustable struts and the 2 degree bushings thinking about going back with the stock struts like ur doing! THANKS!
Old Jun 22, 2016 | 10:11 PM
iamkeniff's Avatar
I would try that. See if someone has a set of coil relocators to try
Old Jun 23, 2016 | 10:13 AM
fillpot's Avatar
Tell me about the coil relocators
Old Jun 23, 2016 | 10:43 AM
RS/SS 4.8's Avatar
10 Second Truck Club
Im running belltech spindle/strut with 2° bushing and dont have any alignment issues.
Old Jun 23, 2016 | 02:07 PM
Feed's Avatar
Can't keep it aligned? Are the upper control arm bolts slipping? Stock bushings have this raised pattern in them which probably helps them grip. The belltech bushings are flat. I have wondered about them slipping but havent had any problems.
Old Jun 24, 2016 | 07:51 PM
iamkeniff's Avatar
It is a base that moves the oem spring down on and oem strut. Basically "stock" front end parts with a 1-2" drop depending the "spacer" used
Old Jun 26, 2016 | 02:06 AM
0235SS93's Avatar
Thighten the **** out of the upper control arm bolts/nuts with a 1/2" breaker bar
LJ93Z28GM
Jun 29, 2016 08:12 PM
mattdavis12340
Apr 28, 2016 12:16 PM
madmann26
Apr 15, 2016 05:57 PM
Chris Johnson
Apr 14, 2016 10:03 AM
SebringSilverZ
Mar 28, 2016 07:48 PM
