AFM/DOD Delete+Cam kit?
Old Mar 3, 2018 | 10:42 PM
Default AFM/DOD Delete+Cam kit?
I keep seeing AFM delete kits, and VVT delete kits. But they all duplicate components. Does no one sell a single AFM/VVT delete kit with a cam and valve springs included?
Old Mar 4, 2018 | 10:35 AM
220Swift's Avatar
I purchased mine from Texas Speed and Performance. I called them and they sent me what i needed plus i replaced the timing chain while this was being done.
Old Mar 4, 2018 | 08:37 PM
I think Texas Speed has AFM and VVTkits that do not duplucate parts. I can obviously get a cam and springs kit from them as well. I will contact them and see if I need any little things I cannot reuse. 👍
Old Mar 5, 2018 | 08:40 AM
Idryfly5's Avatar
I think Gwatney Performance does too.
Old Mar 5, 2018 | 01:47 PM
jamescb77's Avatar
I am also using a texas speed setup and didn't have any duplicate parts unless you choose to add duplicate parts. give them a call everything is very nice and comes packaged well.
Old Mar 5, 2018 | 02:02 PM
Yeah, I have worked with them in the past with my Firebird and they have been good to deal with.
Old Mar 5, 2018 | 04:01 PM
Probably should go ahead and do a new oil pump and timing chain since I will already be in there and the thing has 209k miles on it....
I REALLY hope this is NOT one of the LC9s that has the crank gear @9° off...
Old Mar 5, 2018 | 04:57 PM
220Swift's Avatar
I haven't heard of this. Please elaborate.
Old Mar 6, 2018 | 09:08 AM
A few people have had LC9 engines that were hard to tune. A couple folks on LS1tech found the actual keyway for the crank gear not in the same place as other engines. No one seems to know if it is a VVT thing or random.
Forcefed86 was one. And denmah (Matt Happel-Sloppy Mechanics) even just gave up on an LC9 and called it the voodoo motor because it had issues. I wonder if his was one of the ones with funky crank timing.
https://ls1tech.com/forums/generatio...ing-issue.html
Old Apr 1, 2018 | 06:48 PM
GMNUT's Avatar
I did the tsp afm/dod with their stage 3 truck cam kit and new oil pump and chain. I made 392 rwhp, 374 rwtq on a mustang dyno doing a 2nd gear pull.
