Advice on Fuel system upgrade
Old Nov 19, 2011 | 10:43 AM
nicky g's Avatar
Default Advice on Fuel system upgrade
Has anyone done a fuel system upgrade. Im going with 60 to maybe 80lb injectors on my truck and was wondering if anyone has done any fuel system upgrades like fuel pumps and injectors.
Old Nov 27, 2011 | 10:11 AM
nicky g's Avatar
Has anyone done a fuel pump upgrade on their 08+ silverado?
Old Dec 27, 2011 | 11:47 AM
ivan_key's Avatar
I want to know the same thing, i have an 08 and will need a bigger pump
Old Dec 27, 2011 | 12:01 PM
carbongmc's Avatar
From my personal experience, the flex fuel pumps start to drop off around 600 crank horsepower. Im running FAST 65lb injectors, and made 558rwhp with the pump dropping off from 65psi at the start of the run, to 34psi at the end.
If your staying NA, the stock pump no matter flex fuel or not, should give you what you want. If going FI, anything over 600 at the crank, I would start looking into some type of upgrade.
Old Dec 27, 2011 | 03:14 PM
ivan_key's Avatar
I'm not flex fuel and wanting 700 crank hp, I also have the FPCM and heard you can't just throw an aftermarket pump in it bc the variable voltage pump crap
Old Dec 27, 2011 | 04:11 PM
carbongmc's Avatar
That is correct. Im in the process of trying to find a way to tune out the fpcm now and going with a return style system.
Old Dec 27, 2011 | 04:13 PM
62nalide's Avatar
What motor u got? Reason I ask is because I fried 2 of my pistons at 717hp do u have a fully built motor or stock bottomend? Don't want u to go through what I did blew a new 6.2L with 9,700 miles on the clock
Old Dec 27, 2011 | 06:14 PM
scooter k's Avatar
I'm running a Lonnie's dual pump and return system. It's pretty easy to defeat the FPCM. I'm using the trigger wire from the ECM to FPCM to trigger the aftermarket fuel pump relays. You have to use a transistor to make this work.
You just remove the fuse from the FPCM and tune out the code that sets in the ECM. Racetronix makes the fuel pump wiring harness and relays. I got the transistor from Andy at ADM Performance. Lonnie's performance dual pump setup and I bought all the hoses and fittings from him too. I'm running E85 and fuel system has worked great.
Old Dec 27, 2011 | 08:17 PM
ivan_key's Avatar
I have the 4.8. So I'm going to push it to its limit, I have a spare to go in if I pop it
Old Dec 27, 2011 | 08:29 PM
62nalide's Avatar
ok ok then im sure you be fine 4.8s love boost but are you regapping the piston rings? im not to sure about the 4.8s but my first block i boosted it at 13psi and the rings melted 2gether but good luck on ur build you should try asking foose04 he has his about 16psi on stock bottomend 10sec truck too
