adding a back up camera with factory nav 08 denali
Old Sep 12, 2011 | 10:30 PM
OK just looked up the GM camera accessory installation instructions. The procedure I listed is what has to be done when adding the camera to a OEM nav radio that was not factory equipped with the back up camera. I remembered bumping into this a few months ago and reading it but just wanted to double check.
Old Sep 12, 2011 | 10:31 PM
Lock pick does remedy this and lets you use a variety of different cameras as well as unlocking a lot of the PITA features of the stock deck. You just have to figure a place to mount the camera if not using the OEM bezel style assembly.
Old Sep 13, 2011 | 06:15 AM
gnasty1521's Avatar
Million dollar issue found. Anybody have pictures of where they put their AFTERMARKET camera? I have been debating this install also.
Old Sep 13, 2011 | 08:41 AM
dknoerzer's Avatar
I'm putting in an aftermarket nav head unit and camera this weekend. I mounted the camera last weekend, pretty easy, with just the video cable to the head unit and a power/ground that I hooked up to the 12v outlet in my trunk. I'll let you know how it works out, the whole setup ran about 550, I think the cam by itself is 100 or 150. If you have an aux video in on the factory radio I imagine it would plug right in.
Old Sep 13, 2011 | 09:02 AM
gnasty1521's Avatar
In your trunk? How does that help pickups?
Old Sep 13, 2011 | 09:22 AM
rjwz28's Avatar
Man Motor club
Old Sep 13, 2011 | 02:50 PM
Forum member here I have done some work for mounted the camera flush into the folding door to the right of the license plate where you stick the tire tool in to drop the spare.
But his truck does not have a spare. I didn't do it so the possibility may be there to retain use of the tire winch but I'm not sure
Old Sep 14, 2011 | 07:40 AM
dknoerzer's Avatar
I suppose you would be on your own finding a 12v power source if you have a pickup. Shouldn't be hard.
Old Sep 14, 2011 | 08:20 AM
power it up using the backup lights. If the camera is powered at all times according to gm on their OEM cameras it shortens the camera life.
Old Sep 14, 2011 | 11:10 PM
Wyttrash96's Avatar
I hate my cats
This is what I'm doing. I lost my spare and winch to lose 87 pounds I'll probably never need, and that's exactly where I'm gonna put my camera (el cheapo egay job) once I get the time.
