7 inch drop in the rear .. HELP
Old Oct 5, 2010 | 09:39 PM
silverado1ss89's Avatar
Default 7 inch drop in the rear .. HELP
so i have a 4/6 drop from djm... i want to do it 7 inch in the rear tomorrow... do i have to just out the stick the stock shackle hanger back on??? i couldnt find this online... need help
Old Oct 6, 2010 | 06:50 AM
RibeiroBJJ's Avatar
Praise The Lowered
Not sure what that means but you should have stock hangers/shackles with a flip kit...If you have a flip kit then you could run a rear shackle for more drop (1-2")..If you have shacles/hangers then you need lowering leafs..or remove the overload leaf if you dont use your truck to haul or tow....good for 1.5" +/-
Old Oct 6, 2010 | 12:20 PM
Red04Silverado's Avatar
Yes stick the stock hanger back on and youll sit at 7ins. The shakle lifts the rear when used on a flip kit. I have a DJM 4/7 kit on my 07. Just flip kit and arms
Old Oct 6, 2010 | 03:42 PM
illMATTic's Avatar
Agreed. The stock shackles will set you at 7". All you need is the flip kit. No hangers are shackles.
Old Oct 6, 2010 | 04:33 PM
betz13's Avatar
Definitely use the stock shackle with a flip kit. If I'm not mistaken the flip kit is actually 6" of drop, you get the 7th by taking out the block that comes stock on the truck. I could be wrong tho.
Old Oct 6, 2010 | 05:52 PM
THANKS BRO... YEAH I DROPPED IT AND ITS 7 INCH DROP HELL YEAH.. one problem i thought it had 4/6 but i guess its only dropped 3 inch up front.. so im driving with 3/7 drop.. sucks... i guess ima have to buy the new set off control arm...
Old Oct 6, 2010 | 05:53 PM
What tire size you got on urs... 275 45 20??
Old Oct 6, 2010 | 09:51 PM
javzh's Avatar
buy new control arms? why cant you just get drop struts for the extra 1"?
Old Oct 7, 2010 | 03:26 PM
illMATTic's Avatar
what tire size you got on urs... 275 45 20??
yes they are.
Old Oct 8, 2010 | 07:17 PM
yes they are.
I think i like your tire set up....
Well yeah i think ima look into front strut like a one inch drop will be koo..
i live in gardena.. where djm suspension is located.. mike will hook me up with the control arms $300-350 (basically the whole front parts)... but i dont want to spend that kind money... i was saving up for my stall....
Does anyone recommend some 1 inch drop struts???
