6L80e
Old Jan 19, 2011 | 02:50 PM
Lucille's Avatar
Default 6L80e
What's the max horsepower/torque on the stock 6L80 in our trucks?
Old Jan 19, 2011 | 02:59 PM
Lloyd-TX's Avatar
Here you go . . .
2008 Hydra-Matic 6L80 Transmission ( MYC )
Type: Six speed RWD / AWD, electronically controlled automatic overdrive, transmission with torque converter clutch. Clutch-to-clutch architecture, with integral Electro / Hydraulic Controls Module
Maximum engine power: 469 bhp ( 349 kW )
Maximum engine torque: 439 lb-ft ( 595 Nm )
Maximum gearbox torque: 664 lb-ft ( 900 Nm )
Gear ratios: MYC
First: 4.03
Second: 2.36
Third: 1.53
Fourth: 1.15
Fifth: 0.85
Sixth: 0.67
Reverse: -3.06
Maximum shift speed 6500 rpm
Old Jan 19, 2011 | 03:11 PM
double047's Avatar
14 Second Truck Club
Nice info Lloyd, probably why all the supercharged Camaro guys are ordering up the Circle D units!!!
Old Jan 19, 2011 | 03:19 PM
Lloyd-TX's Avatar
Hey - Google is MY friend, LOL!
Yep - Camaro guys are going to the Circle D upgraded 6L80s - and just consider how much MORE abuse they get in a 5500+ lb. P/U vs. a 4000 Lb. Camaro!
Old Jan 19, 2011 | 03:50 PM
Lucille's Avatar
Great information thanks LLoyd, however I was looking more for real world failure limits, not manufacturer specifications. Allthough, I do wonder how much of a "safety" factor the engineers used.
Old Jan 19, 2011 | 04:35 PM
Lloyd-TX's Avatar
Question
Oops - sorry 'bout that - I should have known better.
The 5th gen Camaro Forums might be a good resource . . .
http://www.camaro5.com/forums/
Old Jan 19, 2011 | 04:54 PM
iamkeniff's Avatar
Skipperdaddy is putting 522rwhp through a stock 6spd/converter/3:42s on 20s. (safe tune) he DD's it an punches off with me every chance we get
Old Jan 19, 2011 | 05:14 PM
JimS's Avatar
Weight and rear end gearing are going to play a role.
Old Jan 19, 2011 | 05:15 PM
Lucille's Avatar
I was hoping you and or Skipperdaddy would chime in. Do you know if he is using the Magnacharger supplied part of the TCM tune? Also, when you say "punch" do you mean roll in or stab the throttle?
By the way - how goes the 6L80 swap in your truck?
Old Jan 19, 2011 | 05:18 PM
Lucille's Avatar
Yeah, I suspect I'm a few hundred pounds heavier than Skipperdaddy since I'm running a 6.0, 6L80, 3.42s also on 20s in a 4x4 Avalanche.
