4:11s to 4:56s
Old Mar 2, 2011 | 07:09 PM
smokin sierra's Avatar
Default 4:11s to 4:56s
Has anyone possibly done it.. I want a lower gear but want to make sure there are gains. Anyone running 4:56s if so whats your take on them... please and thanks
Old Mar 2, 2011 | 07:36 PM
6789olds's Avatar
tire size is very important when choseing gears what tire size are you runing
Old Mar 2, 2011 | 07:56 PM
Old Mar 2, 2011 | 08:21 PM
usmc3521's Avatar
The real question is how much towing does your truck see? 4.56's are great gears especially if like me, your truck lacks in the bottom end. I see you have the 5.3 so that shouldn't be the case. They will add some good off the line acceleration however you may see a loss in the upper end. Also, the rpm's on the highway are a little ridiculous. At 70mph I'm turning 2650 on 30in tires. It's bad but if you have a muffler that drones. That **** gets old quick.
Old Mar 2, 2011 | 08:35 PM
I don't tow at all... mainly street/strip and its a turd until about 25 even with 4:11s .. I most def want to get it up to speed faster but don't wanna lose much topend... and I don't do much highway whatsoever so that's not a issue. And I was hoping going lower would get it up to speed faster?
Old Mar 2, 2011 | 08:58 PM
1Bear's Avatar
With a tire size of under 30”, I would stick with your 4.11’s and instead go with a torque converter to help in getting you off the line better, while still being able to somewhat cruise down the highway comfortably. I don’t see where you have one listed in your sig, so I really believe that should be your next target.
This is coming from someone with 4.56’s, but my tire height is right at 32”.
Old Mar 2, 2011 | 09:37 PM
usmc3521's Avatar
If all you want is acceleration then 1BEAR is right, a converter is the way to go. I suggest a 3000 stall. TB stall is also a good option. Just make sure you get a decent Trans Cooler with it. 4.56's will get you up to speed slightly quicker than 4.11's but no where near the improvement you'd see with a higher stall. Also I suggest a tune to go with it.
Old Mar 2, 2011 | 10:23 PM
Rhino79's Avatar
9 Second Club
A good converter can easily drop you a half sec 1/4 mile. I don't think you'd see much if any gains from 4.10 to 4.56.
Old Mar 2, 2011 | 11:05 PM
usmc3521's Avatar
Performance gains would be small. However, I can tell you that when I used to take my truck up the Carolina Mountains on my way home with them 3.73's, there was a 27% load on my engine even though it dropped to 3rd. The last time I went home I had the 4.56's and the load in OD was only like 11%. Actually, even though I left it in OD, it never dropped a gear once. Small gears like that make your engine and trans' life just a little bit easier.
Old Mar 3, 2011 | 05:43 AM
I'm gonna look into a 3200 stall... does the tranny cooler brand matter?
