3:73 vs 4:10 Gears
Old Oct 5, 2010 | 11:16 AM
  #51
double047's Avatar
14 Second Truck Club
Go 4.11s and be done with it, stronger than 4.10s and basically same gear ratio.
Did 08Chevy say something?
Old Oct 5, 2010 | 11:17 AM
  #52
08Chevy's Avatar
Hey Kevin.....
I said that lol.
Old Oct 5, 2010 | 11:19 AM
  #53
double047's Avatar
Originally Posted by 08Chevy
Hey Kevin.....
I said that lol.
Old Oct 5, 2010 | 05:11 PM
  #54
98sivlerbullet's Avatar
Originally Posted by betz13
Not once have I seen you do donuts. I don't even know if you would be willing to get the rubber from your tire on your truck, you might faint if that happened. Lol
yep betz this is the same person that woudnt go over 75 mph cause it was 99 degrees outside and "YOU KNOW WHAT THIS HEAT CAN DO TO A TRANNY!" lol good times
Old Oct 28, 2010 | 09:46 AM
  #55
double047's Avatar
Haha, I don't know what this about, but it sure sounds funny!
Old Oct 20, 2013 | 07:44 AM
  #56
jasmith31's Avatar
Registered User
Default 373 vs 410 gears
I have an '05 Z-71 crew cab with 6" lift on with 33" tires. It currently has a 3.42 gear in it, which seemed underpowered even before the lift. In the last several months, I have been getting a loud sqeaking noise from the front differential, so... if I am going to have to have it rebuilt, I am thinking about going with either a 3.73 or 4.10 gear. I understand that I will have to do both the front and rear. My question is, as this is a daily driver, mostly highway, how much of a difference in gas mileage am I going to see, better or even worse? When I put the lift on it with the larger tires, it obviously hurt the MPG and also the power, just wondering which gear will be best.
Old Oct 20, 2013 | 12:25 PM
  #57
Ricksilvy's Avatar
With 33" I'd go 4.10s at least. Maybe 4.56s would be better. Mpg shouldn't suffer much.
Old Oct 20, 2013 | 03:11 PM
  #58
craigsix's Avatar
ls motors like the 4.10 gear.
Old Oct 20, 2013 | 04:05 PM
  #59
bigsapper's Avatar
Here's a cool link if you want to factor gear ratio/ rpm/speed...
http://www.powerblocktv.com/resources/
Old Oct 21, 2013 | 04:48 PM
  #60
Z71crawford's Avatar
I have 4.56s and 33" thats the perfect match IMO i do turn some higher RPMs but LS motors like to rev. I turn 2500 at 70 and 3100 at about 90
