2013 Silverado CrewCab Drum to Disc Conversion
Old Jan 22, 2019 | 01:33 PM
  #21
LSCustoms's Avatar
The truck seems to stop much better and I am extremely happy with the install so far...
Old Jan 23, 2019 | 10:57 AM
  #22
Chef_Rome's Avatar
Nice! I just did this on my 08 over New Years weekend. I went ahead and put some russel stainless lines on all 4 corners. I cut the rear hard lines back and double flared them. I need to find some stainless lines to replace the two rear center lines though.
Old Jan 23, 2019 | 11:41 AM
  #23
LSCustoms's Avatar
thanks, I am glad to have gotten it knocked out, had been waiting a while to do it, as i hadnt needed to do a rear brake job on the drums until now... I may make my own lines for the rear and will be swapping them out soon
Old Mar 18, 2019 | 10:01 AM
  #24
LSCustoms's Avatar
I made up some custom ss brake lines the other week...
  #25
LSCustoms's Avatar
Old Mar 18, 2019 | 10:03 AM
  #26
LSCustoms's Avatar
Old Mar 23, 2019 | 10:02 AM
  #27
13chevy370's Avatar
Originally Posted by LSCustoms
Some part numbers:
Parking Brake Anchor (main bracket) 15265913
Backing Plates/Dust Shield 25877333
Parking Brake Adjuster kit 15817021
Caliper Mounting Bolt 18K17001/AcDelco
Brake Hose/Flex 25923716
Brake Hose/Flex 25923717
Rear Left Parking Brake Cable 22851205
Rear Right Parking Brake Cable 22851206
*Parking Brake Shoe Kit 171-0992 (did not have the lever and boot and have to order two)
*Parking Brake assembly kit 89026788 (does have the levers and boots needed for the ebrake)
for the rotors, calipers (including PABs) and ceramic pads, I went with a power stop kit (which has factory re-manufactured calipers). These will be upgraded in the future with z06/wilwoods, or whatever I end up using in the future). Although you can piece together the parts also. And I do have gm part numbers for individual parts.
PowerStop KCOE2083
Nice write up. Do you think the E-brake cables will also work for a 14 bolt. Im going from a 10 bolt drum to a 14 bolt disc set up. I'm having to replace a lot of components as there is a lot of corrosion. Thanks for the info.
Old Jun 13, 2019 | 03:57 PM
  #28
LSCustoms's Avatar
very sorry for the lack of response.. .been working on other non truck related things, didnt get a notification that some posted on the thread... hope you were able to find your answer. not sure if the ebrake components work for your application... if it is the same wheel base, same ebrake assembly, it may.. if i can measure something for you, etc. i am willing to do that for you... if the length of cable would help you determine if it may work
Old Jun 13, 2019 | 04:55 PM
  #29
13chevy370's Avatar
I went with the same cable set up you got. Build almost complete but won’t install the axle until I move, army got me on the move. For others, I had an issue with the E brake pad retaining clips. The reference part only came with one where my axle required two. And they were completely different. But over all, your write up saved me hours of research. Thank you
1bad2k
Aug 13, 2010 07:39 PM
blackbyrd
Jan 19, 2010 04:42 PM
65MLBU
Nov 27, 2007 08:08 PM
TylerCustoms
Aug 18, 2007 09:38 PM
