2011 silverado vibration
Old Feb 17, 2012 | 08:02 PM
Default 2011 silverado vibration
I have this and wanted to know if anyone else is in the same boat
2011 silverado 2wd LT crew cab 5.3L 6-speed auto with 20" wheels
Vibration in the rear of the truck starting about 40 and gets worse with speed but its not horrible
I thought the tires were out of balance so had the dealership rebalance them
No difference
I ran across this
2011 Silverado Vibration = Rough Ride. - Chevrolet Forum - Chevy Enthusiasts Forums
Seems like its happening to 2012's too
Just want to see if anyone else is in the same boat and if you have found a solution
I'm taking it to another dealership, the one I bought it from, and see if we can figure this out
Old Feb 17, 2012 | 08:29 PM
LETHL_SS's Avatar
Mine vibrates pretty much only when the tranny is in 3rd gear and WOT. Other than that it's smooth. I've changed tires but still the same.
Old Feb 17, 2012 | 08:36 PM
My 2008 ext cab was smooth
But I bought the crew for the room
Old Feb 17, 2012 | 10:42 PM
11z71's Avatar
BerryWS6, a friend of mine has the exact same problem with the exact same truck, has had the wheels balanced twice and is still there. The last dealer had told him that it was a normal condition with the factory 20's. Total BS. He's all but ready to get rid of it. Post up your outcome.
Old Feb 19, 2012 | 08:09 AM
Blue04SS's Avatar
I have a 2011 Silvy Crew and going through the same thing. I thought maybe it was my drop since I recently dropped it. I also have the LTZ 20's and also ferl it in the rear not really in the front since I dont feel it on the steering wheel. I did also remove the little washers that hold the drums in place.
Old Feb 19, 2012 | 08:28 PM
cel81xtreme's Avatar
i have this issue also 2011 ext cab. I had it before and after i flipped in the rear 7in.
i noticed it kicked my housing down alittle and moved my axle forward 3/4 of a inch.
same deal thought it was tires(checked them out). Im getting ready remove the leafs and 4link it with pan hard and start making some adjustments in the rear to see if its the pig angle is ******* with me.
Old Feb 19, 2012 | 09:22 PM
well from what I am finding out it seems to be a driveline issue
Im guessing a out of balance driveshaft or a but u-joint..
we'll see tomorrow...
Old Feb 20, 2012 | 09:19 AM
BLACKND's Avatar
Haven't noticed any vibration yet with my 2012 Ext. Cab. Though I am on factory 18's. Didn't read the other thread, is this just happening on the 20's?
Old Feb 20, 2012 | 09:49 AM
No there are some with the clad 18" and the alloy 17"
Old Feb 20, 2012 | 11:15 AM
Here is the tsb
INFORMATION
Bulletin No.: 00-03-10-006F
Date: May 04, 2010
Subject: Information on Tire Radial Force Variation (RFV)
Models:
2011 and Prior GM Passenger Cars and Light Duty Trucks
2010 and Prior HUMMER H2, H3
2009 and Prior Saab 9-7X
2000-2005 Saturn L Series
2003-2007 Saturn ION
Supercede:
This bulletin is being revised to considerably expand the available information on Radial Force Variation (RFV) and should be reviewed in whole. Please discard Corporate Bulletin Number 00-03-10-006E (Section 03 - Suspension).
Important
- Before measuring tires on equipment such as the Hunter GSP9700, the vehicle MUST be driven a minimum of 16 km (10 mi) to ensure removal of any flat-spotting. Refer to Corporate Bulletin Number 03-03-10-007E - Tire/Wheel Characteristics of GM Original Equipment Tires.
- Equipment such as the Hunter GSP9700 MUST be calibrated prior to measuring tire/wheel assemblies for each vehicle.
The purpose of this bulletin is to provide guidance to GM dealers when using tire force variation measurement equipment, such as the Hunter GSP9700. This type of equipment can be a valuable tool in diagnosing vehicle ride concerns. The most common ride concern involving tire radial force variation is highway speed shake on smooth roads.
Tire related smooth road highway speed shake can be caused by three conditions: imbalance, out of round and tire force variation. These three conditions are not necessarily related. All three conditions must be addressed.
Imbalance is normally addressed first, because it is the simpler of the three to correct. Off-vehicle, two plane dynamic wheel balancers are readily available and can accurately correct any imbalance. Balancer calibration and maintenance, proper attachment of the wheel to the balancer, and proper balance weights, are all factors required for a quality balance. However, a perfectly balanced tire/wheel assembly can still be "oval shaped" and cause a vibration.
Before balancing, perform the following procedures.
Tire and Wheel Diagnosis
1. Set the tire pressure to the placard values.
2. With the vehicle raised, ensure the wheels are centered on the hub by loosening all wheel nuts and hand-tightening all nuts first by hand while shaking the wheel, then torque to specifications using a torque wrench, NOT a torque stick.
3. Visually inspect the tires and the wheels. Inspect for evidence of the following conditions and correct as necessary:
- Missing balance weights
- Bent rim flange
- Irregular tire wear
- Incomplete bead seating
- Tire irregularities (including pressure settings)
- Mud/ice build-up in wheel
- Stones in the tire tread
- Remove any aftermarket wheels and/or tires and restore vehicle to original condition prior to diagnosing a smooth road shake condition.
4. Road test the vehicle using the Electronic Vibration Analyzer (EVA) essential tool. Drive for a sufficient distance on a known, smooth road surface to duplicate the condition. Determine if the vehicle is sensitive to brake apply. If the brakes are applied lightly and the pulsation felt in the steering wheel increases, refer to the Brakes section of the service manual that deals with brake-induced pulsation. If you can start to hear the vibration as a low boom noise (in addition to feeling it), but cannot see it, the vehicle likely has a first order (one pulse per propshaft revolution) driveline vibration. Driveline first order vibrations are high enough in frequency that most humans can start to hear them at highway speeds, but are too high to be able to be easily seen. These issues can be caused by driveline imbalance or misalignment. If the vehicle exhibits this low boom and the booming pulses in-and-out on a regular basis (like a throbbing), chances are good that the vehicle could have driveline vibration. This type of vibration is normally felt more in the "seat of the pants" than the steering wheel.
5. Next, record the Hertz (Hz) reading as displayed by the EVA onto the tire data worksheet found at the end of this bulletin. This should be done after a tire break-in period of at least 16 km (10 mi) at 72 km/h (45 mph) or greater, in order to eliminate any possible tire flat-spotting. This reading confirms what the vehicle vibration frequency is prior to vehicle service and documents the amount of improvement occurring as the result of the various steps taken to repair. Completing the Steering Wheel Shake Worksheet below is required. A copy of the completed worksheet must be saved with the R.O. and a copy included with any parts returned to the Warranty Parts Center for analysis. A reading of 35 to 50 Hz typically indicates a first order propshaft vibration. If this is the situation, refer to Corporate Bulletin Number 08-07-30-044D. Generally, a reading between 10 and 20 Hz indicates a tire/wheel vibration and if this is the reading obtained, continue using this bulletin.
If the tire 1st order vibration goes away and stays away during this evaluation, the cause is likely tire flat-spotting. Tire flat-spotting vibration may come and go at any speed over 72 km/h (45 mph) during the first 10 minutes of operation, if vibration continues after 10 minutes of driving at speeds greater than 72 km/h (45 mph), tire flat-spotting can be ruled out as the cause for vibration.
6. If flat-spotting is the cause, provide the explanation that this has occurred due to the vehicle being parked for long periods of time and that the nature of the tire is to take a set. Refer to Corporate Bulletin Number 03-03-10-007E: Information on Tire/Wheel Characteristics (Vibration, Balance, Shake, Flat Spotting) of GM Original Equipment Tires.
7. If the road test indicates a shake/vibration exists, check the imbalance of each tire/wheel assembly on a known, calibrated, off-car dynamic balancer.Make sure the mounting surface of the wheel and the surface of the balancer are absolutely clean and free of debris. Be sure to chose the proper cone/collet for the wheel, and always use the pilot bore for centering. Never center the wheel using the hub-cap bore since it is not a precision machined surface. If any assembly calls for more than 1/4 ounce on either rim flange, remove all balance weights and rebalance to as close to zero as possible. If you can see the vibration (along with feeling it) in the steering wheel (driving straight without your hands on the wheel), it is very likely to be a tire/wheel first order (one pulse per revolution) disturbance. First order disturbances can be caused by imbalance as well as non-uniformities in tires, wheels or hubs. This first order frequency is too low for a human to hear, but if the amplitude is high enough, it can be seen.
If a vibration or shake still exists after balancing, any out of round conditions, of the wheel, and force variation conditions of the tire, must be addressed. Equipment such as the Hunter GSP9700 can address both (it is also a wheel balancer).
Tire radial force vibration (RFV) can be defined as the amount of stiffness variation the tire will produce in one revolution under a constant load. Radial force variation is what the vehicle feels because the load (weight) of the vehicle is always on the tires. Although free runout of tires (not under load) is not always a good indicator of a smooth ride, it is critical that total tire/wheel assembly runout be within specification.
Equipment such as the Hunter GSP9700 loads the tire, similar to on the vehicle, and measures radial force variation of the tire/wheel assembly. Note that the wheel is affecting the tire's RFV measurement at this point. To isolate the wheel, its runout must be measured. This can be easily done on the Hunter, without the need to set up dial indicators. If the wheel meets the runout specification, the tire's RFV can then be addressed.
After measuring the tire/wheel assembly under load, and the wheel alone, the machine then calculates (predicts) the radial force variation of the tire. However, because this is a prediction that can include mounting inaccuracies, and the load wheel is much smaller in diameter than used in tire production, this type of service equipment should NOT be used to audit new tires. Rather, it should be used as a service diagnostic tool to minimize radial force variation of the tire/wheel assembly.
Equipment such as the Hunter GSP9700 does an excellent job of measuring wheel runout, and of finding the low point of the wheel (for runout) and the high point of the tire (for radial force variation). This allows the tire to be matched mounted to the wheel for lowest tire/wheel assembly force variation.
