2009 Silverado lock ?
Old Sep 14, 2013 | 12:19 PM
ricky levins's Avatar
Default 2009 Silverado lock ?
So I have a 09 Silverado z71 and a couple months ago the passenger side door lock has started acting weird sometimes it would work and sometimes it wont its off and on. What could be the problem the lock solenoid? and how much of a task is it to swap that out. Thanks, ricky
Old Sep 14, 2013 | 06:06 PM
Bit's Avatar
Bit
Door lock actuator. If u can take the door panel off, u can replace it.
Old Sep 14, 2013 | 09:16 PM
AUTOT3K's Avatar
if you catch it at a time its not working its easier to test and narrow down to the actuator
but 9/10 times it is that so you can more then likely replace the actuator without worries!
Old Sep 14, 2013 | 10:33 PM
I checked out rock auto and this is what I found is this the right thing I need? Its like 78 bucks. This is the part # DORMAN 931301
Old Sep 15, 2013 | 09:30 PM
AUTOT3K's Avatar
ya thatd be the part
however what I find strange is when I enter 09 silverado and search the sub columns...I cant seem to find the actuator, so where did you find that part number?
Old Sep 15, 2013 | 09:46 PM
KC_kid's Avatar
lots of info here, looks to be very common and you can use a cheap actuator
2008 Silverado Power Door Lock Actuator Failed - Page 18 - Silverado & Sierra 1500 - GM-Trucks.com - Page 18
Old Sep 16, 2013 | 05:58 AM
Autot3k- it was under body exterior door lock actuator. But I think that part number is for the drivers door so I ordered one off ebay for $80.
Old Sep 20, 2013 | 05:41 PM
Thanks for the help guys! Got this fixed today, took me about 45 min. Also fixed the p0449 cel, think its like the evap canister or some crap, truck is like new again.
Old Sep 20, 2013 | 10:24 PM
AUTOT3K's Avatar
its definitely an easy job to do and glad it fixed your problem!
how did you fix the p0449? or just coincidentally it went off after you were done?
Old Sep 21, 2013 | 09:52 AM
I swapped out that canister in front of the fuel tank and that tube that runs over the trans. I ran it up under the hood by the brake booster so hopefully that's a permanent fix. That cel has been on for over a year now it feels weird to not see it there anymore lol
