2007 Silverado Misfire
Old Mar 20, 2015 | 05:24 PM
Silver8ado's Avatar
Unhappy 2007 Silverado Misfire
Check engine light flashing and service traction control / stability trak on start. Truck also shift very hard into first and second gear and has locked the radio. Code comes up as a P0307 (misfire on cylinder 7). Just dropped it off at the shop, any idea how much trouble I'm in?
Old Mar 20, 2015 | 05:40 PM
FFDP's Avatar
Thats a big ole shrug from me.
Too hard to really say, could be as simple as a spark plug or bad plug wire. Maybe even a coil pack.
Alot of vehicles can trip the stabilitrac/traction control lights when certain check engine lights come on. I guess you'll just have to wait to see what they find out.
Old Mar 21, 2015 | 02:44 PM
Silver8ado's Avatar
Hoping its a coil pack and not a collapsed lifter or bad valve. Any idea what those would cost to replace? Might be time for a swap
Old Mar 21, 2015 | 06:11 PM
Jordan927's Avatar
To do it your self, lifters are cheap...60 bucks for an OE lifter if you have AFM.
Bad valve...now your into head removal...If you have it off you may as well do all of em, and put new guides and seals in there...300 bucks ish for parts some new fluids and couple hundred for the machine shop to true the heads.
600 all in I'd say...that's for both heads and all new valves, also includes a new top end gasket kit. (DIY)
If your paying someone else....not cheap
Old Mar 22, 2015 | 10:33 AM
Silver8ado's Avatar
Hopefully not a valve then! $600 without labor and 200k miles on the motor, a swap would seem more appropriate. What is required for a 5.3 (LH6 I believe) to lq4 or lq9 swap? What about a realistic budget including heads and a mild cam for a DD?
ferrellrooster
Mar 6, 2025 03:22 PM
LCHEE
Oct 24, 2020 04:10 PM
Cm_gmt800
Aug 3, 2015 09:13 PM
ferrellrooster
Jul 17, 2015 07:07 AM
Mark_k
Jul 8, 2015 10:44 PM
