2007 escalade ext manual t-case swap/ 4x4hi on pavement 24/7 fluid choice?
Old Mar 20, 2015 | 05:26 PM
Igotlade's Avatar
Default 2007 escalade ext manual t-case swap/ 4x4hi on pavement 24/7 fluid choice?
swapped in a 2012 gmc 1500 manual shift transfer case into my 2007 escalade ext,
I'm going turbo but sprayed a 100dry out of the hole and shattered the bw awd transfer case,
I broke the 10bolt and already swapped the 14bolt sf in, did chromolloy control arms and stainless brake lines ,
my plan is when I'm playing around the street and the track to go 4x4 high... almost all the time
also thinking of swapping my 3.42 to a 4.10 or 3.73... but might stay 3.42 for some wicket boost pulls... I'm running a almost 33 all terrain on a 22" that's about 10-11 wide lowered 5rear 4front with a notched frame rail
for the case swap it was easy... but gota change driveshats mostly because I'm lowered 5inch and swapped the 14bolt in... running a adapter ujoint out back, but thinking a larger driveshaft might help vibration,
also gota extend my front driveshaft apx 1.25inch
so what do you guy think leaving it in 4x4 high on the street I'm running a 32.5x11 wide tire lowered and they are agressive.. on a 22 with a crap shot blocker out back
the plan for t-case fluid is to slightly overfill(d-max guys do it when they run atf because it evaporates a bit, they do 1qt extra via the speed sensor)
I'm going to do just a 1/4 qt overfill or maybe a bit more of either 5-30 synthetic or syncromesh or?? idk what you guys ink
I'm going to run atf in the cold but I figured it will be getting hot if I leave 4x4 high on pavement...
opinions? 5/30, 10/30, syncromesh, manual trans fluid? lucas synthetic oil stabilizer? what's best for running a chain case in 4x4 all the time on the street?
Old Mar 20, 2015 | 05:28 PM
Igotlade's Avatar
Default after the nitrous launch
http://youtu.be/dEPvb_Vq2-A
Old Mar 20, 2015 | 05:33 PM
Igotlade's Avatar
it's nqg rpo mp1222ld mp1222 for the 6l80
http://www.evopower.ca/mrws/filedriver/MP_Transfer_Cases.pdf
some info on the case,
https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/gmt-900-transfer-case-models-explained-473125/
Old Mar 21, 2015 | 11:14 AM
Igotlade's Avatar
did I post on the incorrect area?
Old Mar 21, 2015 | 09:17 PM
Igotlade's Avatar
bump bumpp
Old Mar 22, 2015 | 12:05 PM
mattdavis12340's Avatar
Can't believe no post yet. I'd like to pick your brain on the swap. Got a denali I want to swap
Old Mar 23, 2015 | 08:27 AM
Igotlade's Avatar
what year what case do you currently have... I got answered... haha if you have a awd case than you need to swap the front driveshaft for sure... $50 at a local yard...
Old Mar 23, 2015 | 08:40 AM
GMC93's Avatar
Sounds like its going to be a beast!
Old Mar 23, 2015 | 09:57 AM
Igotlade's Avatar
I'm worried about the manual shift linkage never worked with it before I got one comming from a junkyard for 100 plus shipping... seems overpriced?!
Old Mar 23, 2015 | 10:01 AM
Igotlade's Avatar
too bad Sierra silverado page banned me
anyone know where I can get solid from diff mount bushing for the 07-up front diff... I can not get a 2500 front diff to fit so I want solid mounts... open to ideas on that fellas maybe someone can post over there for me!
