11 sierra from hell
Old Feb 5, 2015 | 09:41 AM
Wareagle23's Avatar
Default 11 sierra from hell
I try to use the search function for most things but I can't find anything on my issue, so here it goes. Changed the o rings in my 4.8 and now out of the blue it won't start unless I get out and press the Schafer valve on the rail. It doesn't do it all the time but it's got me stumped
Old Feb 5, 2015 | 09:50 AM
03sierraslt's Avatar
What O rings?
Old Feb 5, 2015 | 09:58 AM
Wareagle23's Avatar
All of them, upper and lower. Got them from gm
Old Feb 5, 2015 | 10:01 AM
Fuel injector O-rings? Every o ring on the motor? Specifics help
Old Feb 5, 2015 | 11:00 AM
goinbrokez28's Avatar
Does fuel come out when you press the schrader valve? Do you have a fuel pressure gauge?
Old Feb 5, 2015 | 11:01 AM
Jake75's Avatar
Mine was doing the same thing...ended up having to put a return style fuel pressure regulator on and it stopped doing it...it was very annoying ended up smelling like gas everywhere I went because the dam truck wouldn't start unless I bled off pressure from the rail
Old Feb 5, 2015 | 11:30 AM
When you bleed it off is any air coming out?
Jake75- so you just converted to a return system?
Old Feb 5, 2015 | 12:46 PM
Wareagle23's Avatar
Yeah fuel injector o rings. When I bleed it fuel shoots to the top of the hood. I don't have a gauge
Old Feb 5, 2015 | 12:58 PM
Does it do it when the engine is cold?
Old Feb 5, 2015 | 01:27 PM
Wareagle23's Avatar
No. Only after I've been driving it a bit
