09 electrical problem after lighting storm
Old Jun 7, 2010 | 09:10 PM
bad intentions's Avatar
Default 09 electrical problem after lighting storm
Today during one of my summer classes are area got hit with a ton of rain and serve lighting storm. after getting out of class i got in my truck and tired to start it when as soon as i would insert the key and move it towards the aux the truck would try to start on its own...i tried several times till in one turn it fired on but i had no lights in dash expect the service engine going on and off like crazy and the info reading service stabile track and traction control. i was able to drive for about 5 min when the truck just shut down complete... then it rebooted but only the lights would turn on and it wouldn't not turn over.... i have already checked every fuse inside and out and there is none broken... any advice from a tech or anyone please chime in...
Thanks in advanced Jimmy..
Old Jun 7, 2010 | 09:51 PM
blackvmax07's Avatar
check the terminals on the battery, mine did very cloce to the same thing and it was a bad terminal
Old Jun 7, 2010 | 09:58 PM
by any chance did one side of your lights stay on
Old Jun 7, 2010 | 11:15 PM
2004SSS's Avatar
get your truck to a dealer and let them deal with it.
Old Jun 8, 2010 | 04:14 AM
Foxxer's Avatar
As Budhay3s told me before blinking check engine light is a misfire, and it happened to me too (StabliTrak and Traction service), there wasn't any thunder storms here so it was from the ignition wires.
If its under warranty, I would say bring it to your dealer asap.
Old Jun 8, 2010 | 09:22 AM
i want to take it but i have a the mods in the sig that would be pointed to as the fault..
Old Jun 8, 2010 | 12:21 PM
iamkeniff's Avatar
your mods wont stop it honestly. i took mine in with LTs/OR-y/Magnaflow/Truckshop tune/Circle D 3200 stall, Servos
worse that they will tell you is no.
Old Jun 8, 2010 | 12:41 PM
Red04Silverado's Avatar
Youll be fine with those mods going to the dealer
Old Jun 8, 2010 | 01:11 PM
thanks if all else fails i will take it 1st thing this weekend...
Old Jun 8, 2010 | 02:21 PM
tired to do a couple of things to truck it still wont turn on all the lights work radio etc.... but it just wont turn over, also my fuel pump is making a really weird noise.. whenever i put the key forward.... plus my driver side amber lights and rear lights stay on...
