09 crew truck door lock wiring diagrams/PopNlock tailgate lock
Old 07-02-2009, 07:34 PM
the duke35's Avatar
Default 09 crew truck door lock wiring diagrams/PopNlock tailgate lock
Tried to install the PopNLock power tailgate lock-lets you lock/unlock OEM tailgate lock with key fob. Instructions are fuzzy and incomplete. Tech line can only repeat what the printed instructions say...which is to tap into the grey and tan wire behind dash fuse panel. There are several tan and grey wires. Neither worked to activate the actuator. Even tried to tap into the wires behind drivers door panel they feed the door lock latch. There are 4 wires going from door switch to the latch. Still no joy. PopNLock tech line said they would send another wiring harness and relay in case the relays are bad. Anyone have any luck installing this kit? Anyone have wiring diagram for drivers lock/unlock? Very frustrating. This should be simple plug and play. Help.
Old 07-03-2009, 06:30 PM
niugnep's Avatar
There are two styles of lock switches on this truck, I have GM wiring diagrams for both. Its either AU3 or AN3/DL3. PM me with e-mail address and I can send them to you.
5.3Okasai
03-09-2022 01:07 PM
ARC
57
02-21-2022 10:54 AM
wrb002
08-31-2015 12:00 PM
black6spdz
07-16-2015 01:32 AM
Nimoryan
07-05-2015 03:50 PM
Quick Reply: 09 crew truck door lock wiring diagrams/PopNlock tailgate lock
