07 4.8 silverado short block swap question
Old Aug 20, 2014 | 08:02 AM
rcnitrofreek's Avatar
Default 07 4.8 silverado short block swap question
I have a 07 nnbs with stock 4.8 243 heads no vvt or dod and wanted to know what shirt block will work with my 4.8 accessories? Basically my motor has 200k runs great but want more tourqe and easy swap with no bs,so what shirt blocks will fit and work good !! Thanks
Old Aug 20, 2014 | 08:56 AM
cam's Avatar
cam
Im pretty sure iirc that engine is a 58x as all 07+ are ( unless I have it wrong? ) So that said any 58x ( 07+ ) short will be your easiest option. You can use an older engine too but you will have to drop the crank and swap reluctors. The hard parts of the short block are pretty much all interchangeable over the years, its just the top end stuff that varies along with AFM, VVT, and the different sensor configurations and of course the biggie as mentioned the reluctor wheel differences. The best way to go about this is work around your vehicles OS and engine mgmt system. Meaning whatever vehicle you are working with its easiest to retain the harness and ECM tech in place on that vehicle and swap only the new engine parts into it. Plan on a good tune after your all said and done as well.
Old Aug 20, 2014 | 08:05 PM
Thanks!!
Old Sep 10, 2014 | 02:04 PM
5.3parts's Avatar
I just swapped in a LY6 6.0 shortblock in my 08.
chopperloco
Jul 10, 2016 10:45 PM
Castro45
24
Jul 31, 2015 07:13 PM
steves86ta
Jul 28, 2015 10:21 AM
oharajo
Jul 18, 2015 09:24 PM
ALynch
Jul 6, 2015 09:49 AM
