Why wont my heater go off i turned the AC on for the first time and nothing but heat!
Its a 99 with manual controls all of the vents will change but it blows hot like the heater is stuck on.
Iv searched but cant seem to find anything.
Do any of the ***** respond? if you try to change from Face to floor or to dash does it change?
If not the unit could be froze up? Unplug it from the dash and plug it back in to see if it clears up.
Others will chime in with other options
Ya it changed from face to defrost to floor just not hot to cold.
Have someone switch from hot to cold and observe the temp mode blend door actuator to make sure that it moves, if it does not it may be smoked. Also, does the ac compressor kick on when you depress the ac button? Maybe everything's working but there's no R-134a in the system?
