who would I get a new door key cylinder through?
Old Aug 30, 2009 | 02:58 PM
GMCtrk's Avatar
Default who would I get a new door key cylinder through?
When my car was broken into, they destroyed and pushed in the key cylinder in the door handle. Would I have to get a new one through GM? This is a great chance for me to upgrade to the painted yukon handles as well
Old Aug 30, 2009 | 04:03 PM
02BlueStepside's Avatar
Happened to my buddy's impala. Got the cylinder from gm, and they also had to key it to his original key. Want to say it was in the neighborhood of $175. Was like $50 to key it. I suppose you could try and find a cylinder at a junkyard or somewhere and then have it keyed.
Old Aug 30, 2009 | 04:29 PM
GMCtrk's Avatar
Holy Sh*t
In that case I think I will just put a handle on there with no keyhole and remove the cylinder assembly.
Old Aug 30, 2009 | 08:20 PM
CashDudeHomie's Avatar
Several of us probably have them lying around. When I got my Escalade handles, the right one didn't have a key hole. If I run into it anytime soon, I'll let you know.
Old Aug 30, 2009 | 08:23 PM
GMCtrk's Avatar
I have no probelms with not having a key hole on the driver's side. But I just need to figure out what to do with the cylinder and the metal rod inside the door. Right now it's just rattling around inside the door bugging the hell out of me. Hopefully there is a way to just disconnect it.
Old Aug 30, 2009 | 08:39 PM
Here's what I did.
There's a plastic clip holding the cylinder to the metal rod. Unsnap it and remove the cylinder. Then zip tie the rod out of the way so it doesn't interfere when the window rolls up and down.
Old Aug 30, 2009 | 08:40 PM
GMCtrk's Avatar
Thanks. I will do that.
Now I just got to find some pewter door handles, 1 with keyhole and 1 without.
Old Aug 30, 2009 | 09:08 PM
Mangled03gmc's Avatar
Baltimore Whore
Why not just fix it right, still do your mated handles...
Old Aug 30, 2009 | 09:11 PM
GMCtrk's Avatar
because I'm not paying $175 for it. I can count the numbers of times I've ever used the key manually to open the door in the past 9 years on my hand. I'll still have the key hole on the passenger side in case my FOB dies.
Old Aug 30, 2009 | 09:41 PM
Baltimore Whore
I just did a ruff search and found gm lock and cylinders for 27 bucks.. Unless you take it to a dealer, let them dry *** your ***, it will be much less then 175
