Where can I buy these clips?
Old Jul 30, 2005 | 12:28 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Default Where can I buy these clips?
I figured out my misfires are from crappy connections with the injectors. I am looking to buy new clips and solder them on to replace the old ones that seem to get loose all by themsleves. Any idea where I can get just the clips? They are on a 2002 5.3 Z Flex Fuel Tahoe.
[IMG][/IMG]
Old Jul 30, 2005 | 12:39 PM
budhayes3's Avatar
PT's Slowest Truck
Maybe GMpartsDirect.com? I guess you'd probably need part numbers first...you could try a dealership. If you go to ACDelco.com you might be able to find part#'s also...
or, you could try removing the terminal ends from the connectors and squishing them closed a little tighter...
Old Jul 30, 2005 | 01:01 PM
BlownChevy's Avatar
blownerator
25 Year Member
mmmm flex fuel injector clips....let me research that a bit and get back to you.
Old Jul 30, 2005 | 01:04 PM
BlownChevy's Avatar
blownerator
25 Year Member
According to what I have found GM is having a problem with the injectors on your year, make and model....you might want to look into that.
Old Jul 30, 2005 | 02:03 PM
1SlowHoe's Avatar
Is there a service bulletin on them?
OHsixLS3
Nov 22, 2015 07:45 PM
nabozny21
Oct 17, 2015 07:47 PM
JoshH
Sep 28, 2015 11:19 AM
sTNT971
Sep 26, 2015 04:22 PM
