wheel speed sensor recall
#21
Originally Posted by jjauto
He's right, this will not cause the speedo to do any thing. The wheel speed sensors are abs related. I have done about 5 of these recals so far. The worse I have seen so far is when you hit the brakes at a slow speed (1-10mph) the abs activates and causes you to travel a little further before stopping (3-6 ft). It can set codes as well. Basically the dealer cleans the rust from the speed sensor mounting surface and inspects the sensor for any flaws, bends, etc, then reinstalls or replaces the sensor. I haven't had to replace any yet, just clean. There should be no reason to reflash the computer. The only thing computer related would be clearing codes.
#22
Originally Posted by blake2kz71
can somebody get a pic of where these are located for future reference? the way my luck is with this truck il end up having to so something with them.
#23
Originally Posted by LesPaul
hmmmm... my speedo stopped jerking after i replaced the tranny.... also... thier is a recall out replacing the wheel speed sensor... why would i make that up?? its only for 99-02 models
Everyone ready the Sticky thread about re-calls and info and I'll check your VIN#'s personally and tell you if you got a re-call.
#25
Wait, I'm confused...I received the recall notice in the mail and had it done a year or so ago
. I did a google search and found the recall number: NHTSA Campaign ID Number: 05V379000
http://www.google.com/search?sourcei...+Sensor+Recall
Corvette454l88
Sep 1, 2016 01:24 AM
OHsixLS3
Aug 10, 2015 07:19 PM
