whats the trick to make a cam sensor stop leaking?
Old May 11, 2021 | 01:12 PM
  #131
rwagoner's Avatar
That was my next thing.... I have read also about loosening the bellhousing bolts and re-torquing the pan bolts, but mine didn't leak a drop of oil until about 150,000 miles so I am guessing they didn't just suddenly loosen.
Thanks for the info!
Originally Posted by 00pooterSS
It can drip for quite a while or at least show to be wet.
One drop of oil can spread out to a quarter size spot pretty easily so it doesn't take much.
If you haven't done an oil pan gasket do one of those next, they are notorious for leaking
Old May 12, 2021 | 01:27 PM
  #132
00pooterSS's Avatar
Re snugging isn't likely to help. The rubber hardens over time and loses it's ability to seal, the metal border and the tabs on the oil pan only allow the gasket to get crushed so much, so any snugging won't compress the rubber any further.
You're welcome man, good luck!
Old May 12, 2021 | 09:53 PM
  #133
rwagoner's Avatar
You're right - didn't work. I am pretty sure it is the gasket, though ... in one part I can see the oil slowly coming through as the engine runs and I don't see it coming down from the side at all.
Thanks!
Old May 12, 2021 | 11:08 PM
  #134
jclark10's Avatar
Thanks!
So if you put a "block off plate" on the oil cooler, what did you do with the oil cooler lines?
Old May 12, 2021 | 11:27 PM
  #135
rwagoner's Avatar
Mine never had the oil cooler, so it's just the factory block plate thing (actually a mis-named part as it allows oil to travel through it).
Now I need to figure out a good rack and pinion replacement, but that's a different thread ...
terravast4
Jun 23, 2016 03:57 PM
nickleahy23
19
Sep 26, 2014 03:27 PM
SuperStepside
Jul 5, 2012 01:14 PM
4.8chevysilverado07
Feb 22, 2012 12:44 PM
Flyer
May 14, 2004 10:52 AM
