whats the difference?
Old Nov 26, 2007 | 11:28 PM
TexCrew's Avatar
Default whats the difference?
what is the difference between a lq9 and an lq4? how much are they for a rebuildable one? maybe if my christmas bonus is big enough i can buy the one from Tootall...lol
Old Nov 27, 2007 | 01:18 PM
NegraRCSB2X4auto's Avatar
I think the lq9 has a little stronger internals.
Old Nov 27, 2007 | 01:56 PM
Nick™'s Avatar
difference is pistons and rods, if you plan to replace those components then it doesn't matter which one you get.
Old Nov 27, 2007 | 02:29 PM
UBLUZIN03's Avatar
the lq9 has higher comp. too..
Old Nov 27, 2007 | 02:32 PM
Tootall's Avatar
high compression, flat top pistons, bigger rods (HD)
same 317 heads
same cranks
They're easy to rebuild. You can find a 04 and up, LQ4 "rebuildable core" and rebuild it with flat top pistons if you wanted to
Old Nov 27, 2007 | 06:41 PM
TexCrew's Avatar
i found one on ebay. i hear that the 6.0 conversion is a good mod to make.
Old Nov 27, 2007 | 07:42 PM
nick993's Avatar
when in doubt...punch it out.
Old Nov 27, 2007 | 07:51 PM
Mangled03gmc's Avatar
Baltimore Whore
Also in 04 both the motors had the same internals, other then the 9 still haven the higher comp..
John
Old Nov 27, 2007 | 09:43 PM
BlackLM7's Avatar
LQ9 has flat top pistons and the LQ4 pistons have a small dish to them. The differences in the pistons give the LQ9 a 10:1 compression ratio while the LQ4 only has a 9.4:1 compression ratio. Both engines have 317 heads (except earlier years) and *I THINK* the LQ9 has stronger rods. Not sure about that....
Old Nov 28, 2007 | 08:35 AM
ap2002's Avatar
so im guessing after you watched us race last friday at the track you got bitten hard by the mod bug!! do it!!
