What would you buy? '09 Colorado 5.3 or '08 RCSB 5.3 4x4?
Old Mar 11, 2009 | 07:24 AM
Kylemsu720's Avatar
Default What would you buy? '09 Colorado 5.3 or '08 RCSB 5.3 4x4?
That is the question I'm debating. I thought I had settled on what my next vehicle will be, a RCSB Silverado 5.3 4wd. Then I started looking more and more into the new Colorado 5.3 ZQ8. Keep in mind this will be a daily driver, and I'll be living in Michigan with it. What do you guys think?
Old Mar 11, 2009 | 07:42 AM
nighthawk08's Avatar
i've had a colorad, a canyon, and now a RCSB GMT900.
The colorado will obviously be faster, and it will probably get better gas mileage. everything is is MUCH better on the GMT900's. The build quality, the engineering, everything.
Old Mar 11, 2009 | 07:47 AM
Kylemsu720's Avatar
My biggest thought is whether or not I'll want 4wd or not. The other thing that I liked about the Colorado was the extended cab leaves room to throw some stuff behind the front seat if need be. Living in MI I think I'll really prefer the 4wd, although I've owned a couple 2wd trucks in the past, and they weren't that bad. I do like the idea of 4HI launches as well.
Old Mar 11, 2009 | 07:54 AM
that is true. I am a little dissapointed with the behind seat storage in the GMT900 regular cab. but the ext cab colorado is pretty long and has a shitty turning radius.
Old Mar 11, 2009 | 08:07 AM
cheyenne383's Avatar
TOWN CRIER
Fullsize, a lot more capable, better engineered/build quality, and better looking in my opinion.
Old Mar 11, 2009 | 08:14 AM
Kylemsu720's Avatar
It sounds like RCSB will be the choice. I've done some looking around, what does it take to get a '08 RCSB 5.3L 4x4 into the 14s?
Old Mar 11, 2009 | 08:51 AM
venomhp's Avatar
resale is also better when you compare a full size to a mid size for a gm truck, I would go with the rcsb 4x4
Old Mar 11, 2009 | 09:49 AM
not much. a good tune may do it. if not a small converter does wonders
Old Mar 11, 2009 | 10:11 AM
Kylemsu720's Avatar
That's all I needed to know... I'll be modding whatever I get anyways, but was curious what I'd be starting with...
Old Mar 11, 2009 | 11:18 AM
Mark Johnson's Avatar
'08 RCSB 5.3 4x4.....................
