What.will I run
I should be putting my new motor in hopefully before the weeks out. Just waiting on head gaskets and some other small stuff. I been reading how quick some of y'alls trucks are and was just curious how fast I should be at the track? My truck is a 2000 sierra RC.
My new motor is a 6.0 bored .030 over with mahle pistons, comp hyd roller 54-4 12-11
Cam grind xr265hr, 1200-1600, 265/271, 212/218, 522/529, 114 lobe sep angle.
Comp lifters
Complete valve job
Circle d stage 2 278mm 2a
60# injectors
Magnum 72mm turbo
I really want to be just as quick as a Lighting or close to it.
Comp lifters
Complete valve job
60# injectors
Magnum 72mm turbo
it really depends on the tune and just how much boost you plan on running..
if the tune is a lil off and it freaks out its gonna be slow haha. i went from a 14.3 to a 13.2 with just dialing in the tune years ago on 6psi. i was learning how to tune and my first pass was horrific..
Do you have a wideband to keep an eye on AFR?
oh and my neighbor has a lighting and with a upgraded blower, lower 4# pulley, tune and W/M injection he only went a 12.8 to my 12.9 and i was running half the boost he was.
One thing is when I would get on it, it would only pull for a little and the wastgate would dump to me right in the middle of pulling. Plus it seems to break up to I put some ngk 4177 pkugs and gapped them to 29 and that help a little.
[/IMG]
