What lube for squeaky suspension bushings?
Old Oct 22, 2018 | 11:30 PM
Ferocity02's Avatar
Default What lube for squeaky suspension bushings?
My 2001 Silverado has 135,000 miles with stock suspension other than a 2/4 drop. Recently the bushings have started to squeak badly, especially the rear. I sprayed them all with WD40 which worked great for about 3 months, then the squeaking came back even worse.
I know the best solution is to replace the bushings all together, but is there an aerosol spray that works better than WD40? Even if it only lasts 6 months I would be happy.
Old Oct 23, 2018 | 05:41 AM
RB04Av's Avatar
5 Year Member
Try spray silicone lube.
Old Oct 23, 2018 | 11:26 AM
BudRacing's Avatar
Look for something "marine grade" as it tends to have better water shedding traits.
Old Nov 14, 2018 | 10:22 PM
GoatChs's Avatar
WD-40 Specialist Multipurpose Grease is marine rated and you can get it a Walmart.
bobfig
Jul 31, 2013 11:38 AM
jessdog
Jun 16, 2005 04:54 PM
Sexyblu03
May 21, 2005 01:38 AM
abbo7
May 8, 2005 01:43 AM
MarineBlue03GMC
13
Mar 1, 2003 07:44 PM
