what do i need to get run LOW 12's, maybe even get into the 11's?
Old Jan 21, 2012 | 02:19 PM
2doorfury's Avatar
Default what do i need to get run LOW 12's, maybe even get into the 11's?
ive been searching around, trying to find good setups. and havent found exactly what im looking for..like the title says..but im trying to do it without forced induction. i have the stuff in my signature and plan on ordering 4.10's and true trac next. then on to power making parts..but what? i was thinking stage 2.5 heads and a good cam? i seen a member running 12.20's with basically the same setup as me with the 2.5 heads and a good cam. whats everyones take??
Old Jan 21, 2012 | 02:50 PM
tarinitup's Avatar
9 Second Truck Club
What do you run now?
Old Jan 21, 2012 | 04:08 PM
skolman91's Avatar
6L swap with heads and cam will get you consistent mid 12s, then add a decent shot for 11s. Trust me its gonna be harder than you think to get low 12s with a 5.3, do the 6L swap before you waist alot of time and money..
Old Jan 21, 2012 | 04:16 PM
00ecsb6.0's Avatar
Agreed ^^ My buddy did a 6.0 swap with thunder racing classic cam, cut 317's, converter and shift kit with 373's and ran 12.32 in a rcsb with 20's
Old Jan 22, 2012 | 12:51 AM
2doorfury's Avatar
well 6.0 swap isnt going to happen yet..but theres a future for that..but for now. im going to beat up on the perfictly good 5.3 that in the truck now..so low 12's on a 5.3 isnt goin to happen N/A..so what could i run with heads/cam and bolt on's?
Old Jan 22, 2012 | 12:52 AM
2doorfury's Avatar
never ran the truck..not too sure what it does yet.
Old Jan 22, 2012 | 01:26 AM
A Low Dime's Avatar
13 Second Truck Club
There have been just a select few who have managed low 12s with N/A 5.3, but those were setups that were combined perfectly and those runs were perfect. Its something most people wont be able to reproduce.
That being said, a cammed/stalled/bolt on 5.3 single cab normally runs 13.1-13.5, but a large majority on PT still only manage 13.5-14.0s with the same setup.
H/C and all the bolt ons, you SHOULD run 12.6-12.90s, but again, plenty of people can put together the correct combo and would still only run 13.0-13.5 with heads and cam. Those numbers would be with slicks, good traction, nice weather, low DA etc. etc.
Old Jan 22, 2012 | 01:28 AM
A Low Dime's Avatar
Also depends on how much cam and converter you can handle also.
You can toss in a 4400 converter and nice big cam and have a real beast that runs 12.0xs in awesome weather.
Old Jan 22, 2012 | 01:34 AM
La Simple Sam's Avatar
I ran a 12.4 @105 on 5.3 constantly h/c/i with a 180k motor lol ....have a friend that ran a 11.9 on his 5.3 set up and another a 12.01 also 5.3 h/c/i....
Old Jan 22, 2012 | 01:38 AM
A Low Dime's Avatar
You are kind of leading this guy on, you know those set ups were a bit more radical than most people on here want to put on their trucks.
PLUS, the DA down there at nighttime when you guys run is WAY better than most of these guys even understand. There is probably .3-.5 tenths just in the awesome weather alone.
What kind of converter and cams were in those trucks? 4.56s or 4.10s? What kind of heads? Were those on Bogarts also?
